Results 1 to 11 of 11
Thread: Gaea Terrains, and high polygon displacements
    May the sauce be with you starbase1's Avatar
    London, UK
    5,585
    Hi All,
    I've been using the new Gaea terrain tool with Lightwave, and I'm rather impressed. It generated high bit depth maps or OBJ files, and the Erosion options are wonderfully realistic - it can make separate maps of things like alluvial features, areas eroded, and where the deposits end up, which also help with texturing.
    Sample attached.
    However I am hitting the limits of memory using the maps as a displacement on a subdiv surface, roughly 4k x 4k maps and 16 million polygons.
    (LW 2019 and LW 11.6 no significant difference I can see...)
    Is there a way, short of an expensive memory upgrade, of handling more?
    Test animation here:
    https://vimeo.com/337743742
    Thanks,
    Nick
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    Feb 2006
    england
    1,193
    instead of using SUBd plane, try using a null with flat plane geometry (add null, properties, primitive, change primitive type to shape, change shape to plane,) its slower to render but has no division limit so will be equal to the image but 0 geometry
    Intel i7 5960X Extreme, Asus Rampage V extreme, 3x 4gb NVIDIA Geforce GTX970, 32GB DDR4 2666 corsair dominator
    Aug 2010
    Kernow
    2,072
    Like so.
    London, UK
    5,585
    Thanks, will give that a go - sounds like a 2019 thing, yes? Not really got to grips with that yet.
    In the meantime, I just finished a short animation of that terrestrial crater, and I'm rather happy with the result! Love the way you can see the debris from the erosion washed towards the middle...
    https://vimeo.com/338341972
    Nick
    San Jose, CA
    6,486
    Quote Originally Posted by XswampyX View Post
    Like so.
    51m51s for a single 1920x960 frame? Yikes, that's quite painful. What's the resolution (pixel & color res) of the maps used, and for what?
    John W.
    London, UK
    5,585
    All those soft reflections won't be helping though...
    Feb 2006
    england
    1,193
    doesn't have to be too slow to render, I did this back in the early days of 2018, the ground is a displaced null and the image only took 20 mins at 7680x2160(and that was on my older 5960!), even has lots of transparency going on in the poly tunnels, on top of that there is probably about 12 million or so polys going on as I didn't bother optimising anything
    Aug 2010
    Kernow
    2,072
    Of course. I didn't do a quick render to show how quick it was. I think my displacement amount was too large so it created a lot of extra geometry.
    Here's the scene if anybody can get it lower... ?
    Island.zip
    Jun 2014
    Right here
    1,506
    Very nice!
    Jun 2014
    Right here
    1,506
    Quote Originally Posted by starbase1 View Post
    Nick
    Looking great!
    I enjoy using Gaea too. The primitives in LW2018 / 2019 render with great detail but I would prefer having visible object deformation with sub poly displacement in order to align / place objects or characters on it or having a viewport representation of the displaced plane. But for background terrain renders it works well.
    Another option could be to use the exported OBJ file and add procedural normal maps in the LW material for close up details.
    London, UK
    5,585
    Yes, I like the way you can feed in rough shapes, and use erosion node to make them really natural looking..
