Results 1 to 12 of 12
Thread: strange shadows / artifacts / splotches
    Registered User antoniomitalia's Avatar
    Aug 2010
    Spain
    8
    Hi everybody, I'm driving crazy with this simple turntable scene. I've subdivide the model to the limit, then triple it, no non-planar polygons, no more than 4 sides, al of them subpatch. I extracted this animated GIF:
    These are my GI settings. I was reducing the angular tolerance and maximum pixel spacing also to the limit, but problem continued. Also lot of primary and secondary rays and also interpolation softness:
Name:	gi settings.jpg
    I also disabled the normal maps and blurred the HDRI, but nothing.
    Any ideas are welcome!
    I would try using an Environment light as your only light. Turn off "Enable GI" completely. Then set the intensity of your Environment light to 1 to match the intensity of your backdrop. It defaults to sampling the Backdrop settings (Gradient backdrop, Image World, etc.).
    The problem is, interpolated Gi is activated.
    when the interpolated is in use, you must to enable interpolated cache. They work together.
    Or use brute force alone
    Near Beaverton, OR
    1,939
    As mentioned, you should use an Environmental light.
    For aerial items, I came across this one that I like a lot.
    https://hdrmaps.com/freebies/above-the-clouds
    Also, your settings are extremely excessive. I know you were most likely experimenting. But this is also related to the light in that you need to set the samples for the light itself.
    I'm still working on this one myself but should give you some decent starting points:
Name:	LW Settings.jpg
    The Big Apexx System:
    64GB
    Aug 2010
    Spain
    8
    Thanks Kevin, that solved the problem!
    Since it looks good, unfortunately I wasn't able to achieve exactly the cool look of GI:
    Quote Originally Posted by antoniomitalia View Post
    Glad it helped. If you do want the look of GI, you could do aperezg mentioned above. Use Brute Force GI without interpolation turned on. Just set your Rays to 1 or 2 and slowly work up if needed. That will render fast without any of the flickering you were getting.
    Nov 2003
    jersey
    5,792
    You're getting double reflections is why its different... if you're using envirolight, either... turn off "affect specular" for the light and have the surface's reflection shading options set to raytrace+BG... or... set surface reflection to raytrace only and enable spec for the light.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Aug 2010
    Spain
    8
    Thanks everybody for the ideas!! I finally solved the thing!! RebellHill, turning off "affect specular" gave me the point to add enviro as secondary light, leaving my initial light (distant with sunspot) to affect only specular in the model, so I've got that oranged sun reflections that reveal all the bump work.
    That hdr is the one I was using, Ma3rk! it's a 10 BTW nice model you did!
    Alejandro I activated interpolated cache to continue using GI, testing each mode (all 4), clearing cache each time, animation also activated, but splotches didn't disappear
    Nov 2003
    jersey
    5,792
    Interpolated cache only works for camera only motion. You can use interpolated for other types of motion, but it takes a bit of wrangling to get right. For something like this, envirolight is by far the best option, if you have it set up right, your results should be little to no different from GI.
    RHN Nodal Tutorials
    Aug 2010
    Spain
    8
    For everybody interested in final result:
    https://www.behance.net/gallery/8238...4U-Corsair-CGI
    That looks really cool. Great job on the model.
    Aug 2010
    Spain
    8
    Thanks Kevin! it's such an honor
