Thread: Raycast node for Blocking instances
    LW Junkie squeegie's Avatar
    Central Florida
    90
    Found a neato thing... not sure if anyone else does this or not so I thought I'd share.
    I always hated having to use alpha map to block out areas that I don't want grass (under driveways, foundations, etc). I started tinkering with using the RayCast Geometry node to generate a weight map and BAM!
    Nice and clean clipping of the instances with no maps or extra geometry needed.
    <insert clever signature here>
    Thats going to be useful.
    Thanks.
    Robert Wilson, MA Deaf Ed.
    Indiana Deaf School
    1,795
    thats really cool, thanks for sharing.
    1,350
    Quote Originally Posted by squeegie View Post
    Might you have a sample scene you could post? Looks very useful but some of us are nodally challenged so having something in hand to fiddle & poke helps a lot.
    Central Florida
    90
    Raycast Grass.zip
    Sure thing! Here is a simplified version. I'm a bit node-clunky as well, but if you have any questions I can try to answer them.
    1,350
    Gratzi! Will take a look at it a bit later.
    7,891
    Alpha? Why you didn't use weight map, with Vertex Maps > Weight node?
    Did you see my way of handling intersecting instances?
    https://www.youtube.com/watch?v=P6p-Cm_PFyc&t
    This saves render time also.. Because to fill instances so close that they don't have gaps, you need to use couple times (4-10x) more instances, than when they are uniformly placed.
