Thread: Raycast node for Blocking instances
    LW Junkie squeegie's Avatar
    Central Florida
    97
    Found a neato thing... not sure if anyone else does this or not so I thought I'd share.
    I always hated having to use alpha map to block out areas that I don't want grass (under driveways, foundations, etc). I started tinkering with using the RayCast Geometry node to generate a weight map and BAM!
    Nice and clean clipping of the instances with no maps or extra geometry needed.
    <insert clever signature here>
    Thats going to be useful.
    Thanks.
    Robert Wilson, MA Deaf Ed.
    Indiana Deaf School
    Aug 2016
    a place
    2,367
    thats really cool, thanks for sharing.
    Near Beaverton, OR
    1,948
    Quote Originally Posted by squeegie View Post
    Might you have a sample scene you could post? Looks very useful but some of us are nodally challenged so having something in hand to fiddle & poke helps a lot.
    The Big Apexx System:
    64GB
    Central Florida
    97
    Raycast Grass.zip
    Sure thing! Here is a simplified version. I'm a bit node-clunky as well, but if you have any questions I can try to answer them.
    Near Beaverton, OR
    1,948
    Gratzi! Will take a look at it a bit later.
    64GB
    8,154
    Alpha? Why you didn't use weight map, with Vertex Maps > Weight node?
    Did you see my way of handling intersecting instances?
    https://www.youtube.com/watch?v=P6p-Cm_PFyc&t
    This saves render time also.. Because to fill instances so close that they don't have gaps, you need to use couple times (4-10x) more instances, than when they are uniformly placed.
