Results 1 to 15 of 16
Thread: AE3 HDMI and DVI tricaster 8000
    Nov 2016
    uk
    6
    Hi All,
    Apologies for this question, we still learning how to use the tricaster. We have bought the AE3 upgrade and in the email it said
    NewTek Customer Advisory: TCAE3 Display Options
    With the introduction of TriCaster Advanced Edition 3, there is a change that affects the display outputs of TriCaster systems.
    With the implementation of new features and capabilities, the display outputs (also referred to as Display Ports) such as DVI and HDMI from the system motherboard have been disabled.
    Anyone had an issue with this?
    19,331
    You are correct, the so-called "Display Port" implementation does not exist in AE3. Generally, for display needs previously supported by this mechanism, you're going to need to split another video output (such as SDI) or work out a method to use NDI (which has profound advantages for many purposes).
    Aug 2016
    USA
    489
    So let me ask, IS this why our second multiview monitor stopped working on out TC1?
    What are my options to get this back working?
    19,331
    Quote Originally Posted by Stream View Post
    No, I don't think so, because TC1 never had *Display Ports afaik. (* This was always unfortunate nomenclature, because people tended to confuse it with the later-appearing physical port by the same name.)
    Nov 2016
    uk
    6
    Thanks Steve for the prompt reply, still getting to grips with ndi, we use our dvi port to connect to a scaler to project on led screens and we connect HDMI splitter to HDMI port to TVs. We are a church based in the uk. Is there any way I can use ndi using some of the connect spark family.
    19,331
    Before getting into a consideration of alternatives, it would be interesting to figure out which HDMI port you were using, and what had changed that resulted in this no longer working for you. Maybe post a cell phone shot showing which hardware port you're referring to, to begin?
    Nov 2016
    uk
    6
    Thanks Steve, good point haven’t even installed AE3 yet, will install and test will get back to you once I know which ports are not working. Thanks again.
    Registered User Red Dog Records's Avatar
    May 2008
    Northern California
    293
    Quote Originally Posted by bashie View Post
    Bashie,
    When we upgraded our 460 to AE3, we only lost one of the HDMI outputs. One of the other one still works great as a program out.
    Also, we didn't change any of our two multiview monitor connections. One is HDMI and the other is DVI. When we first booted up, one of them was black and the other had the new (AE3) Tricaster menu on it.
    If we went into an existing session, we would get program out on one monitor and the other would be black.
    We simply when into Admin mode and selected the 'swap monitors' option. Now everything works great.
    BUT - we still have to swap monitors every time we boot up our system.
    Hope that helps,
    Andrew
    Tricaster 460AE3 + LC-11
    Flypack: Router, switch, backup encoders, captioning devices, audio mixer, UPS, etc
    Cameras: Sony Z280, Z150, Spark & Bird Dog converters
    http://reddogrecords.com
    Nov 2016
    uk
    6
    Thanks Andrew, will bear that in mind when upgrade is done.
    19,331
    Quote Originally Posted by Red Dog Records View Post
    Have you bugged this, Andrew?
    May 2008
    Northern California
    293
    Not yet. We just upgraded to the latest version of AE3 so we will see if it is still an issue.
    Andrew
    Aug 2016
    USA
    489
    One the image, I only get a signal out of the HDMI port. I use to also get a signal from the port to the right of it.Click image for larger version.
    19,331
    So, not to be facetious, but I think something is wrong with your TC1 ... software, setup, hdwe., not sure. I just tested mine here (which is admittedly not exactly 100% standard) and have not trouble using all three of those ports - two for different external multiviews, and the other for the UI.
    Aug 2016
    USA
    489
    Thanks Steve. I'll have to check it out. It was working fine. Someone else was using it and then it wasn't working. Maybe it's time to do a restore.
    Nov 2016
    uk
    6
    Hi All, AE3 installed, all ports working with the exception of 1 hdmi port, which just displays Newtek.
