Results 1 to 2 of 2
Thread: Chroma key processing impact video quality?
    Jun 2018
    Chicago
    9
    I may not have done a very good job of explaining my ongoing dilemma with getting a good green screen set.
    When we are doing a show, I've noticed the "real" stuff in the show, like the talent, isn't as crisp as the background that is keyed in. The talent appears to be a little soft or dull in the image. The virtual background looks very crisp and clear. It's not a huge difference, but it has been pointed out to me by others as well, so it is noticeable.
    Could there be an issue with the processing that's happing inside the Tricaster that is causing problems? Could a setting be off?
    If I can't figure out a solution, I will likely have to abandon the green screen set and build something real. Unfortunately, I have quite a bit of money sunk into this green screen setup, so I don't want to do that.
    Help!
    Aug 2016
    USA
    494
    Is it your camera?
    Have you tried any of the sample green screen footage that comes with the Tricaster?
    Do you see the same thing?
