Results 1 to 15 of 16
Thread: Really unusual lighting wanted!
    May the sauce be with you starbase1's Avatar
    London, UK
    5,585
    Here's an odd one. I'm doing things with a high resolution displacement mapped moon model. All nice and accurate.
    One of the bad things though is that, as with the real Moon, there are no craters visible except near the terminator, where the sun shines down at a very shallow angle.
    And I'd like them to show everywhere. I got a partial result by blending one view lit from the left and one from the right, but I'd really like something where every segment is lit at the same shallow angle, and I'd like to do it without heavy photoshop work, as that would be a pain to animate.
    So, any thoughts on how to illuminate every polygon from the same direction relative to the polygon?
    Nick
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    England
    5,837
    My initial thought is crazy, and not sure if it'd work or not but:
    How about unwrapping the actual moon mesh, so it lays flat. Like UV unwrapped, but the actual mesh. You could do it as a morph target.
    Then light the unwrapped sphere, using a directional light. Then bake the shadows as a map. Then multiply that shadow buffer into the material of the spherical moon.
    Does that make any sense?
    Desk Work:
    Desk Home:
    Mar 2012
    Socal
    399
    A normal map is basically an emboss convolution, but in 3 color channels. Using a grayscale version of your normal map as a color map as well should do the job, I would think. Does that make sense?
    London, UK
    5,585
    Thanks Lardbros, Yes! That sounds like a really good solution! Given the nature of the lighting I was expecting to end up baking it anyway.
    Thank You!
    I'd had some vague thoughts about building directional light baffles that would be visible to rays and not the camera, but could not think of a practical way of doing that.
    London, UK
    5,585
    Dan - it's a displacement map - I see what you are getting at I think, but I really like the unwrap idea.
    Thanks for the help though.
    England
    5,837
    Actually, Dan's suggestion might be easier.
    If I'm understanding what he means, you could take just the blue (or green, or red) channel of a normal map, and then as its greyscale, use it to multiply over the top of your colour.
    Desk Work:
    Desk Home:
    Nov 2003
    jersey
    5,766
    The ol spinning light trick?
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    London, UK
    5,585
    Aha! Map building seems to have worked nicely.
    London, UK
    5,585
    And a render of the resulting map wrapped.
    Aug 2010
    Kernow
    2,072
    Quote Originally Posted by starbase1 View Post
    I don't like it at all.
    It looks like a render from Lw 5 done by somebody who doesn't know what they are doing.
    Sorry for being so blunt!
    And I'm not saying you don't know what you are doing.
    Edit :-
    Just light it like any object.
    England
    5,837
    Glad it worked but...
    I kind of disregarded the reason behind why you wanted this in the first place.
    Why do you want it like that?
    Desk Work:
    Desk Home:
    London, UK
    5,585
    Well, I'm looking for a way to show craters across the whole globe, rather than just along the terminator. This makes it possible to directly compare cratering on different parts of the Moon knowing that other factors are the same.
    I'm already getting results - for example, it has become clear to me that the Aitken basin is not just a depression, but also has MUCH lower relief on the crater walls.
    I can also see value in using it for maps, again showing all the craters.
    England
    5,837
    Ah, so more of a "visual research" type thing? That's cool
    Desk Work:
    Desk Home:
    Mar 2018
    Perth, Australia
    65
    Why not zoom in on certain areas and leave the lighting as realistic as possible? I created a displaced moon surface and had a ball going all over the place with it. If you want to emphasise a certain feature it is better to zoom in on those areas.
    Don't forget to zoom in on the image :-)
    London, UK
    5,585
    I already have a very high res realistic Moon, what I want to do is see features on different parts of the Moon >>under the same lighting conditions<<.
    For another example take a look at the result I pasted earlier. By showing all the craters, you can really see the long chains of craters radiating away from Mare Orientale, (slightly below and right of the centre).
