Thread: PNG Alpha Channel - STILL
    May 2012
    Virginia
    530
    After all this time, I thought I had put my alpha channel issues behind me.
    Nope.... still here.
    Created a beard stubble texture for a character; everything but the beard stubble is transparent.
    Bring it into LW, plug image node to color on Principled BSDF.
    Whole face turns a shade darker.
    Why? The image is plugged into Color and the only color in the image is the beard. Why is it shading the entire face? Why doesn't LW ignore the alpha portions of the image?
    Nov 2003
    jersey
    5,792
    Change the background colour in the image node.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    May 2012
    Virginia
    530
    I tried that with a simple color node; it had the desired result of changing the skin tone back to its normal color, but it also removed (hid?) the non-alpha portions of the PNG, i.e., the "beard stubble".
    I fed the color node into the background for the image. Was this incorrect?
    Nov 2003
    jersey
    5,792
    You feed it to the BG colour on the image node, or jsut change the bg colour swatch in the node.. either.
    RHN Nodal Tutorials
    Member jgutwin's Avatar
    Portland, Maine, USA
    43
    It would be nice to have an over-drop style image node.
    John Gutwin
    Pepperchrome
    May 2012
    Virginia
    530
    Ahhh.... Thank you! I think I remember now.... That's the same problem I've had before with the alpha channel in a texture image darkening the base color of the material.
    You hit the nail on the head... I think I need to run white into the background color. I'll check it tomorrow.
    It's just the logic of the nodes, they don't 'inherit' the base colour of the material, as they did in layers, because the 'base' layer is always the material colour/value itself. Instead they override the colour, so if there's nothing in your BG colour, it's just black by default. Nodes stack from left to right, where the last node is the base colour/value, layers go from top down to the base colour. It would conceptually be messy to 'inherit' the base colour of the object, when using nodes.
