Results 1 to 2 of 2
Thread: Error Processing.NDI.lib.x64.dll Exception thrown.
    Apr 2019
    France
    1
    I'm currently working on encoding and managing NDI feeds with SDKs and I am experiencing an error that I have not corrected.
    The error is as follows:
    Exception thrown at 0x00007FFD9FD72990 (Processing.NDI.Lib.x64.dll) in NDIManagement.exe: 0xC0000005: Access Violation while reading location 0x00000280C1AAB060.
    I try to circumvent the exception or change my way of proceeding impossible to solve this.
    The error is due to the return declaration of the video_frame stream with "NDIlib_send_send_v2(pNDI, &video_frame)" No matter how the program crashes with this error after 300 frame send.
    If anyone has a solution to my problem?
    Registered User roddyp's Avatar
    Sep 2017
    UK
    29
    Quote Originally Posted by theokoel View Post
    Without you posting some of the code, no.
    However, the usual problem with this is that the pointer you pass as the video_frame's p_data parameter doesn't actually point to the beginning of the frame data - or, that the FourCC code or stride don't match the actual layout, so the encoder is reading past the end of valid memory.
    If you're using Windows bitmaps, a "gotcha" that we found is that bitmap scanlines are typically ordered "backwards" in memory - so passing the address of scanline zero is actually near the end of the memory block, not the start!
    A neat workaround for this is to pass a negative value for "line_stride_in_bytes" to the send_video function.
