Page 1 of 5 123 ... LastLast
Results 1 to 15 of 68
Thread: Flowing water native emitters and HV
    Mar 2009
    Durban
    272
    Mar 2006
    in lights
    2,167
    wow! i loved it .. i can use it everywhere if you share your settings ))
    quite nice!  
    Mar 2009
    Durban
    272
    My Scene File
    Cool! Thank You.
    Mar 2009
    Durban
    272
    An old test scene I found all native particles ... this was to test blending and scale over time probably could be useful for an object or head coming up through the ground or product reveal ...
    if you find this stuff fun, be sure to check out Hurley's UP
    https://www.youtube.com/user/HurleyworksInc/videos
    Jan 2004
    Boston
    409
    Very well done!
    Mar 2006
    in lights
    2,167
    thank you
    Mar 2009
    Durban
    272
    Not 100% perfect still some puff balls need tweaking but this is all hypervoxels .....
    Combines 1 Volume Shader for Smoke 2 Volume Shaders for Fire with 1 Sprite Shader for Outer soft glow effect
    2nd volume shader is abit clumpy will upload smoother version next version flow on all channels are using
    Turbulence Effect of 50% amp and 100% speed effect.
    impressive!
    knowing the limitations of HyperVoxels for that kind of simulation, quite impressive.  
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,138
    Nice retro vibes. This takes me back 20 years when I played with hypervoxels a lot. How long setup time and render times for these tests?
    Mar 2009
    Durban
    272
    Render for the Moving Smoke was about an hour at 720p , Fire Setup was about the same
    Setup time for smoke an be done in 10 minutes or less just ad a null stick the emmiter to it ad an oscillator done you just need to know settings for hv
    Setup for fire took some time more cos i kept changing it and testing stuff since it was a first attempt
    [reason for doing this there are so many bad examples on youtube really makes lw look bad even
    the content newtek puts out with particle stuff smh]
    test renders and messing around 3hours i guess but once you have the settings down its quick.
    Still hv can be used for certain assets if you not going for ultra realistic smoke or fire simulation add motion blur to get away with it.
