Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 68
Thread: Lw_ui+
  1. #46
    Hi raymondtrace, i do not know about OD_Workspaces but i can tell you that Lw_UI+ use the same restore mecanism in Modeler as in Layout.
  2. #47
    >> Trial Version Available! <<
    LW_UI+ is now version 2020.4
    2020.1
    -Several stability and speed fixes
    -New Menu, more simple and elegant
    -Fix UI artefact in Hide Title Mode
    -Transparent Mode for Node Editor OR/AND Graph Editor OR Both.
    -New Setup installer with/without Workspaces
    -New Manual
    2020.2
    -2x+ Faster
    -No more flickering when panel havn’t changed
    -Shift+Click through the superposed and transparent Node Editor
    -Pause read the ini config
    2020.3
    -Fixes Graph Editor Resize
    2020.4
    -Fixes LWSurface/MD_Image bug
    -Fixes Modeler AutoSize Panels
    -Demo Version
    -AutoPause Mode for CTRL+number workspace
    -Transparent Morph Mixer
    -UI_Empty fix
  3. #48
    The Trial version is now 2020.5.
    - It wasn't able to store any workspaces in Num 0-9, Sorry about that.
    - somes fix have be done too
  4. #49
    LW_UI+ is now 2020.8
    - Lot of Bug fixed
    - Demo is now 7 days period
  5. #50
    LW_UI+ is now 2020.11
    - Several Fixes
    - Workspaces can be saved with Force Dynamic or Force Manual Option
    - Hide mode is no more experimental but stable
    - Check for update button
    - Autofit of the Scene Editor or Modeler Tools are now an optional mode.
    - Add shortcuts to some Lightwave panels that don't have any by default:
    Ctrl NUM / to open the Custom Item Panel
    Ctrl NUM * to Fold/Unfold Surface & Image Editors
    -Control Transparency of panels with Ctrl NUM +/-
  6. #51
    LW_UI+ is now version 2020.18
    - Optionable SHIFT+CTRL replacement for SHIFT+ALT
    - Add Fold/Unfold Attribut to Layout And Modeler (Auto Show/Hide Tool)
    - Panels Attributs stored in Workspaces (Transparency, AlwaysOnTop)
    - Add Fold/Unfold Attribut to Surface & Image Editor
    - Embbeded Octane IPR in Layout OpenGl
    - Embedded Nodal Editor in Layout OpenGl
    - Transparency Nodal onto Octane IPR
    - Renamed Config File.
    - Compile x64
    - Less False Positive (2/70)
    - Sharp and Clean No Border Mode
    - Fixes
ID:	146941 Click image for larger version.
ID:	146940 Click image for larger version.
    Lightwave Project: Igorrr - Very Noise By Meat Dept (David Nicolas)
  7. #52
    Murcia, Spain
    3,127
    Papou for those of us who have purchased how do we download the update, do we grab the trail version.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  8. #53
    Quote Originally Posted by JohnMarchant View Post
    Hi John, No, i will send you a email soon.
    I have removed the plugin for the now.
    It will be back soon.
  9. #54
    Murcia, Spain
    3,127
    Hi Papou, thanks for that mate.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  10. #55
    LW_UI+ is now version 2020.21
    - CTRL+ENTER will help conforming the actual 1920x1080 workspace to any resolution, with/without taskbar
    - Fixe a 2019 order of openGl slot in Layout (4,1,2,3) that was breaking Octane and nodal embedding
    - Better detection of the loading status of Octane before it can be embedded into OpenGl
    - add an advert in the installation process to warn user about false positif and lazy free antivirus detection.
  11. #56
    LW_UI+ is now version 2020.22
    - Optional workspace startup
    - Screen Resolution detection & auto install workspaces
    (1920x1080,1920x1200,2560x1440,3840x2160)
    - Separate AutoFit for Modeler & Layout
    - Fix Modeler Surface Preset opening
    - Fix Modeler do not Maximized in No Border Mode
    - Fix GraphEd with Border when poping in noborder mode
    - Fix (OpenCurrentItem)
    - Fix Taskbar detection in modeler autofit mode
    - Fix Corrupted workspaces when save too fast
    - Fix the Scene Editor miss to fit to the screen height
    - Fix Conform Workspace on multi screen
  12. #57
    PAPOUSUPERFASTUPDATE
    I will test it this evening !
    Phil
    Ryzen Threadripper 2990WX 32 Cores - 64 Threads / 2 x GTX 1080 + 1 GTX 1070 / Windows 10 x64 / 64 Go Ram / LW2019 & Softimage user
  13. #58
    The workspaces folder is different now, it add screen resolution.
    It may be better to save your workspaces, uninstall.
    Then install.
    Not necessary but cleaner.
  14. #59
    Murcia, Spain
    3,127
    Cant wait to get the update, screen resolution detection looks great.
    Dell XPS 15
    Windows 10 64Bit
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  15. #60
    Several fixes.
    [2020.23]
    - Fix Surface Presets opening/closing
    - Fix Display Options resize in 3640x2160
    - Fix Scene Editor Fit when swaping workspaces
    - Fix Scene Editor Fit with Light Properties in 2019
    - Fix 2018 missing workspaces in previous installer
    - Fix the always available Update Checker
    - Fix Highlight around some panels in Border mode
