Thread: Integration NDI to Legislative Room
    Apr 2019
    Brazil
    Hello
    I am planning the purchase of 4 cameras Newtek PTZ NDI and Tricaster TC1 for a legislative room.
    The cameras will connect only by Lan network.
    There is a way to control the automation move: send some command to camera, that allows to positioning the camera in a specific place.
    When a microphone is activated to a legislator, we have to automate the position of the corresponding camera: for this, we have a web interface that sends a command to an audio server and should send the position to a corresponding camera.
    Is there a way to automate domotica via ethernet?
    Quote Originally Posted by ltricarique View Post
    Hello
    Can the web interface application you are using send RESTful API commands? If it can, then this would be possible.
    Apr 2019
    Brazil
    The web application is developed with java. Where can I see the Rest API commands that I can send?
    Thank you
    Aug 2015
    london
    290
    Hello
    You might be interested in the Sienna NDI Processing Engine. Amongst many other facilities, it includes the AI Mix module which uses audio-level cues to control vision mixing or to send out metadata messages which can recall NDI PTZ Camera presents.
    http://www.sienna-tv.com/ndi/ndiprocessor.html
    19,859
    Just in case it wasn't obvious, TriCaster's audio mixer can trigger macros based on input level. Of course this doesn't help much if you are doing all your mixing externally.
