Results 1 to 15 of 18
Thread: LightWave 2019
    LightWave 2019
    Well I didn't know 2019 had Tools for Game Dev...… and I just missed a sale
    Will there be a 30 day trial offered for 2019?
    If it is I don't see it in my account Downloads.
    and If not, why not? I tell ya what
    How bout another Sale so I can scoop it up
    May 2007
    Belfort, France
    1,865
    There is a trial for LW2019, but you have to request a specific serial number here :
    https://www.lightwave3d.com/try_lightwave/
    the Trial is alright, somewhat.
    but the demo mode in Modeler is useless with poly-limitation, luckily you can model in 2015 and import it into 2019.
    (NewTek, take note. Houdini Apprentice and Blender is way ahead of you) Fix the demo-mode! Thanks.
    prices might go down with Vizrt running the show. Let's see.  
    2,009
    maybe...
    today's first laugh!   
    Thanks for the link
    Old Dog Learns New Tricks RudySchneider's Avatar
    Jan 2006
    Lincoln, CA
    1,307
    maybe...
    That gave me a laugh, too.
    Ahhh... If only it were so...
    There are no problems, only opportunities...
    7,964
    But as soon as you will apply LW 2019 surfacing, LWO will stop being openable and editable in LW 2015.
    yup.
    NewTek needs to boost both the trial mode and the demo mode. a win-win situation.
    also give LightWave to schools for free. (at least for a few years)
    1,540
    Mmmm. Not 100% correct. Oliver has some tools for that but done't know what he ended calling it.
    https://vimeo.com/search?q=OD_LoadSave%20
    Ohio
    1,007
    This topic is mixing things up a bit.
    The trial is a fully functional version for 30 days. There should be no restrictions. After the 30 day trial period, the software turns to unlicensed or "discovery mode", which includes the poly-limitation with Modeler and no ability to save scenes from Layout. Discovery mode lasts indefinitely, so you can take your time to learn LW before purchasing.
    In the context of a 2019 trial (or discovery mode), this shouldn't be a concern. Erikals is simply pointing out how you can bring more complex geometry from a previously licensed Modeler to load into "discovery mode" of Layout 2019. There's no need to open and edit again in LW 2015 if one is just testing 2019. And if you're using the fully-functional 30-day 2019 trial, there's no need to import complex LWO from an older version. Modeler 2019 should work fine, without functional limitation.
    I would suggest that the biggest fault of LightWave Discovery Mode is that NewTek does not make it discoverable in its marketing. Who knows about it, except for us licensed users? NewTek hasn't marketed to new users for over a decade. Why should they start now?
    of course, that wasn't the point though. the point was,
    > demo mode in Modeler is useless with its heavy poly-limitation.
    > Houdini Apprentice and Blender is way ahead in this regard.
    Vizrt gives the situation hope.
    Ohio
    1,007
    Right, I was just clarifying because VonBon was only asking about a 30-day trial. Discovery mode, while a general issue for LW adoption, is probably not a concern.
    Modeler's discovery mode limitation is 400 points per layer. However, there is no restriction on the number of layers. So if you're creative, you can still build very complex geometry in the crippled edition.
    2,009
    400 points? how anyone gonna test anything with that?
    15,807
    for 30 days you should be able to use it full out, before it goes in to discovery mode, after that.. the limitation setīs in, and if you have older lightwave versions such as 2015 you can use that, there isnīt much new in modeler except for live array and some other small stuff.
    So if you have 2015, you can just work with that and import and modify, but not save.
