Results 1 to 9 of 9
Thread: Sliders deactive once I leave frame 0. Help!!!
    Super Member Paul_Boland's Avatar
    Nov 2003
    Waterford, Ireland.
    1,101
    Exclamation Sliders deactive once I leave frame 0. Help!!!
    Hi Folks.
    Well this is a weird one... When I go to animate any object with Sliders on it, the sliders as you can see are available for use on frame 0, but once I leave that, frame 1, 2, 10, 100, 1000, etc., the sliders become deactivated and are totally unavailable. I have checked this on my desktop computer and laptop and it's happening on both, with any scene file I load. Anyone got any ideas because I've never seen this before?
Name:	Sliders Problem.jpg
    KnightTrek Productions
    http://www.knighttrek.com
    Nov 2003
    Waterford, Ireland.
    1,101
    Oh my God, I just did a test. Create a cube, layer 1. Copy to layer 2. Save.
    Go into Layout. Parent layer 2 cube to layer 1 cube. Select layer 1 cube. Add Sliders control in Properties. Set up a basic rotate layer 2 cube control.
    When on frame 0, it is available for use. When I move to frame 1 it becomes unavailable. Trying to think what could be causing this and the fact it's happening on every scene on both machines, the only thing I can think of is a recent Windows update that both computers got. Please don't tell me this has messed this all up on me! Is there any way to fix this? Am I missing something obvious?
    Jan 2005
    Colorado Springs
    1,844
    Works fine for me in LW2015.3, Win64 as from your screen capture. Scene attached. Are you accidentally hitting SPACE and disabling the Sliders? Does CTRL-D work to re-enable them if you're off of Frame 0?
    mTp
    Attached Files Attached Files
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,689
    Paul, from your images it looks like they only highlight on a keyframe (f0) but when moved to where there isn't a keyframe the slider greys out.
    Hope this helps
    Nov 2003
    jersey
    5,792
    Like daforum says, they light up to indicate the presence of a keyframe, they havent deactivated.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Nov 2003
    Waterford, Ireland.
    1,101
    Thanks very much for the help, folks. I've done some testing and I think I've found a problem.
    First, you're right, the sliders do dim when not on a keyframe, sorry about the confusion there. But look at this image here:
Name:	Sliders Problem 2.jpg
    The slider controls of Prizonian 1's left hand have disappeared completely. When I got into Properties -> Sliders, all the controls are gone.
    So I then took the test file above and I did a test... I Clone Hierarchy on the two boxes and look:
Name:	Sliders Problem 3.jpg
    All the sliders end up linked together but only the original box turns. I think the Clone Hierarchy tool and Sliders don't work well together, at least in Lightwave 2015. I can still do my renders in these scene, but I'll have to keep this in mind for future use where I need multiple copies of a character.
    Thanks for all the help, much appreciated.
    Aug 2016
    a place
    2,072
    what if you import a character from scene instead of using clone hierarchy, will that fix the problem ? I recall it fixes a problem for some other issues.
    Nov 2003
    Waterford, Ireland.
    1,101
    That worked. When I love each copy individually from file, the slider controls are fine. Thanks for that.
    San Jose, CA
    6,790
    Quote Originally Posted by Paul_Boland View Post
    Can someone with LW2019 please test and confirm/deny whether the above problem still exists?
    If so, it really needs to be reported -- that behavior suggests "clone hierarchy" is actually corrupting cloned hierarchies, and such corruption would also likely be responsible for other issues/failures.
    John W.
