Results 1 to 8 of 8
Thread: source name
    Jun 2018
    NYC
    10
    source name
    I believe the only way to set a source name is in the Sender constructor, like this:
    Code:
    Sender sender = new Sender("My Source Name");
    Is it possible to modify the sender name afterwards?
    If not, is this a possible future enhancement to the SDK?
    I haven't been in-front of my code for months, but I'm not sure if you can set it to be named from something like a combo box or text box.
    Code:
    Sender sender = new Sender(myTxtBoxName.Text);
    This might require to start and stop the sender, but it could work.
    John Erbicella
    Experienced in TriCaster, OBS, and various streaming solutions
    Web: http://www.jperbicella.com
    Twitter: @JPErbicella
    YouTube: https://www.youtube.com/jperbicella
    Jun 2018
    NYC
    10
    John,
    Yes, that works but it requires re-initializing the Sender. I would like to set the name AFTER the Sender initializes.
    Jun 2018
    NYC
    10
    Bumping up in case someone from NewTek can respond.
    Registered User roddyp's Avatar
    Sep 2017
    UK
    29
    Quote Originally Posted by jgeduldig View Post
    Not from NewTek, but I'm curious what you're trying to to achieve here.
    The name given when you create a sender is how receivers locate (and select) your source. If you change the name, what do you want receivers using the old name to do?
    Depending on what you're after, either the connection metadata functions like NDIlib_send_add_connection_metadata or the NDI-ROUTING functions (which allow you to bind an existing source to a virtual output) might be relevant.
    Jun 2018
    NYC
    10
    That is a good point about receivers of the old name.
    I am streaming web pages over NDI, and users want to see the web page in the source name. However, the web page will change after the connection is established.
    The majority of solicitous out there use a set name similar to scan converter - maybe "My PC-Browser" "My PC-Microsoft Word" etc. but none use the name for the reason listed below. It may be possible to use the metadata (mentioned above) to display a line of text on the receiver, and be able to disable this for record or broadcast (assuming this is the end coal). To carry page name as the sender name would otherwise require one sender per page (I think).
    John Erbicella
    Jun 2018
    NYC
    10
    Okay - this all makes good sense. Thank you!
