Results 1 to 9 of 9
Thread: Modeler Visibility Problem
    Jun 2010
    Kranj
    102
    Hi
    I am having problems with LW 2019.0.3 Modeler.
    As you can see from attached files, active background layer hides geometry of an active layer.
ID:	144662Click image for larger version.
ID:	144663Click image for larger version.
    Top viewport should show geometry of an active layer.
    This is only present in this version, in 2019.0.1 everything works fine.
    I have already uninstalled and reinstalled but the problem is the same.
    Anyone knows what is going on?
    Pessac
    5,051
    It doesn't look so odd to me? The only way that uninstalling and reinstalling will cure a possible config problem is to choose the "Uninstall settings" option when you uninstall. Either that or visit c:\<user>\.NewTek and delete the directory for the version of LightWave you are having problems with.
    HTH,
    B
    LightWave 3D Trial Edition
    Aug 2017
    Slo
    74
    Works OK with my 2019.03
    Jun 2010
    Kranj
    102
    Shouldn't active layer visibility overrun background visibility? Now, in top viewport, looks like there is no geometry...but there is
    @next_noob: yup, this is what I am after
    medzo - I can confirm this bug on three different installs of 2019.03. I've reported it. Funny it was in the 2019.03 release fixes info as :LB-5650 geometry is hidden behind the grid or the origin. But I never experienced that on 2019.02 and now this. And it doesn't have anything to do with the origin or grid as shown in the attached screen shots. Again I have confirmed this on three different installs of 2019.03 - two with Quadro cards and one TI-1050. The one user that is not experiencing this is using 2019.02.
    Tim Parsons
    Technical Designer
    Sauder Woodworking Co.
    http://www.sauder.com
    Have you ever used LW before BeeVee?
    Tim Parsons
    Technical Designer
    Aug 2017
    Slo
    74
    Yes, 2019.0.3 does not show correctly foreground/background layers. It simply shows geometry that is "closer to observer" in specific viewport and not geometry that it is on foreground layer.
    Jun 2010
    Kranj
    102
    So, we should wait for 2019.0.4 version? Or is there anything we can do now?
    Quote Originally Posted by medzo View Post
    Use 2019.0.2?
    Tim Parsons
    Technical Designer
