Thread: Forcing a morph to inflate a satelite
    May the sauce be with you starbase1's Avatar
    London, UK
    5,604
    Hi All.
    I've got 2 versions of an object, and I want to morph between them.
    It's actually an inflatable sub satellite, which starts looking like a square umbrella, then flips into something curved with inflated ribs.
    Now the good news is that I don't need photo realistic, and that the movement between versions can happen along one axis, so things like points crossing over shouldn't be an issue. Also I can get away with the deflated one being zero thickness. The bad news is that points are nothing like the same, and it's a CAD export. High poly.
    So my thinking is that I should force a copy the inflated version into the shape of the deflated one in some way. Then I can morph between the two.
    Is there a tool that will help me do this please?
    Nick
    Picture of 2 states:
Name:	force morph.jpg
    Faith is the opposite of Intelligence.
    Touched by his noodley appendage!
    My Lightwave Graphics & Downloads!!!
    Super Member Kevbarnes's Avatar
    Nov 2006
    Gloucestershire UK
    511
    what you could try is splitting the deformation into two morphs, note that morphs are linear translation.
    if you created a morph 'out' of the mesh - in XY plane only, then another for the Z plane
    you can generate a more curved translation of vertices when they act together.
    Control both with one or two nulls
    Creating morph - try make a copy of one state then use Heatshrink, (havn't used it for ages)
    "one rig to rule them all"
    PC Spec: Intel i7 X980 3.33GHz | 24Gb | ATI FirePro V5800 | W7
    https://vimeo.com/kevbarnes/showreel
    https://littlstar.com/kevbarnes
    https://www.talenthouse.com/kevbarnes
    Jan 2005
    Colorado Springs
    1,823
    The Heat Shrink tool might allow you to create a morph of the inflated version down to the uninflated version.
    mTp
    London, UK
    5,604
    Ah. heat shrink looks promising, not used that before - thanks
    London, UK
    5,604
    London, UK
    5,604
    Got the results I needed via heat shrink on one axis, after a bot of experimentation.
    Anyone else using the tool, it;s well worth trying all the options.
    Jan 2013
    NA
    88
    Give "Layout | Object Properties | Deform | Effector" a try.
