Thread: Best Solution for capturing Laptop video/audio
Hybrid View
    Jan 2015
    Ohio
    7
    First sorry for this basic question. I have a laptop running a powerpoint with audio. Laptop HDMI port is connected to projector. What is the best way to bring video and audio into Tricaster? NewTek NDI Scan Converter?
    Registered User vdmc's Avatar
    Nov 2009
    USA, Southeast
    27
    If you have the laptop and the TRICASTER on the same network - Download the NDI scan converter app for the power point computer- connect to the network and start the NDI scan converter- This will send the PPT image to the TC - The NDI image will have to be assigned/picked in one of your TC inputs. Audio from the laptop not so sure if audio follows NDI. I only use PPT w/out sound.
    Feb 2019
    Czech republic
    18
    Scan Converter works just fine, we use it anytime we need to record presentation from a PC. You can select which audio output is sent with the NDI signal (if you have for example regular audio jacks or audio via HDMI; or you can send nothing). If you have displays set to extended, you choose which one you receive in TC.
    Only drawback is that it doesn't work on Win7. Vmix has a similar (also free) app that works on W7, but I haven't tried it as we are running W10 everywhere already.
