Results 1 to 8 of 8
Thread: Tweaking the areavol.p plugin
    Cumbria UK
    402
    A lot of the work I do requires specific weights of materials, which I have as 'grams per cubic cm'. I am constantly having to run areavol.p then enter the result into a calculator to convert to cubic cm, then to grams.
    I'd love to have a version of areavol.p which returns...
    a) the volume as cubic cm.
    and
    b) as grams.
    I have one main material which is 1.325 grams per cubic cm, so the maths is simple enough.
    It'd be nice to have a plugin which allows me to edit the grams per cm3, just in case the material density changes. I'm guessing an lscript can be edited in a text editor to make such an adjustment, and I'm assuming it would complicate things quite a bit to consider adding an option/interface to enter different densities.
    Anyway. Bearing in mind I know practically nothing about programming, do you think this is a simple enough tweak? Is it something I could accomplish once pointed in the right direction? Or are there any scripting experts out there who could manage it without breaking a sweat?
    Cheers,
    Derek
    Murcia, Spain
    3,005
    I hope you have put in a feature request.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    Cumbria UK
    402
    Cheers John,
    I haven't put in a feature request yet, I was hoping it was a simple amendment to an existing plugin.
    If others think it'd be useful, then I'll get round to doing a proper feature request.
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,473
    It's fairly straight forward.
    Lightwave's native unit is the Meter. So, you'd compute the volume in meters, multiply by 100^3 (100 cm to the meter) to convert to cubic centimeters, then multiply by the weight per cubic cm.
    Simple dialog box (or a drop down list) for entry of the material, then press OK to get your volume and mass.
    However, computing the volume of an arbitrary solid is a non-trivial task. I'd have to consult some computational geometry references for the correct algorithm.
    I wonder if it's related to the surface area of an arbitrary polygon in 3D, which I use in my FFX calculator...
    *edit* It's do-able. A little math intensive, but do-able.
    My Scripts for Lightwave
    Cumbria UK
    402
    Hi Kryslin,
    Yeah, converting the volume from cubic metres then into grams is straightforward.
    Computing the volume in the first place, less so... LOL
    I've just discovered that when Lightwolf posted the 64 bit version, he included Ernie wright's original source code...
    https://forums.newtek.com/showthread...plugin-for-x64
    So when I get a moment, I should be able to go through it, and figure out where to do the conversion. Then I need to figure out how to compile a plugin... Sure that can't be too hard.
    Feb 2009
    Prescott, IA
    1,473
    I'll probably make an lscript of it, too. And, of course, Oliver will probably add it to ODTools.
    Cumbria UK
    402
    I've submitted this as a feature request. Thought it may be useful to others, including anyone doing 3D printing.
    Not that I don't trust your coding skills Kryslin, but I thought it would be handy to have as a native tool.
    Feb 2009
    Prescott, IA
    1,473
    I've got to find the time to actually _do_ it. Right now, that's kind of a problem.
