Thread: Ethernet Cards on TC1 config
    Registered User edunova's Avatar
    Oct 2018
    Italy
    4
    Question Ethernet Cards on TC1 config
    Hi everyone,
    I'm sorry for my probably dully question... but I really do not understand the meaning (and configuration) of the the two ethernet cards on TC1.
    1. Are they intended to give redundancy on connection (such as streaming...)?
    2. If yes, should they be on the same subnet?
    3. I have all my devices (TC1, sparks, PTZ1, laptops...) connected by a switch in dhcp mode. Moving to different places with this live setup, I need in every place to use a certain IP address to stream (provided by local organization). If I want to benefit of 2 eth cards redundancy, will I have to ask for 2 IP address to stream or should I set my switch saying it both cards appear externally with a unique IP (if it's possible, I'm not skilled in networking)?
    Thanks a lot,
    regards!
    fab
    Aug 2016
    USA
    495
    I was told while doing a Live Gaming Event, where we had 16 NDI inputs coming into the TC1 that plugging in a second ethernet cable from the same switch would in effect double our bandwidth and help with some of the stuttering issues we were experiencing when I had 8 NDI sources in Program and the other 8 in Preview. I was streaming out two different shows, one from program and one from preview at the same time.
    Oct 2018
    Italy
    4
    Thanks.
    I was also wondering if makes sense to use one ethernet card only to stream (linked to the external net) and the other one linked to our switch where are linked all the NDI sources (therefore all internal)...
    Any helps?
    Technical Account Manager - Channel Support
    Sep 2005
    NewTek
    1,693
    2 Nics gives you flexibility in how you set things up.
    Zane Condren
    NewTek Inc.
    new.tk/call
