Results 1 to 12 of 12
Thread: Lock Control Surface?
    Jul 2018
    San Diego, CA
    27
    Anybody have any neat tricks for locking the control surface on a TC-1? We leave live replays rolling sometimes and it would be disastrous if someone were to inadvertently hit a button on the CS and kill the show. Unplugging the ethernet cable from the CS works but then you have to dump out of live mode to reconnect it when you want to use it again.
    Does anyone have any more elegant solutions?
    TIA!
    Do you mean locking the entire CS or just certain buttons? There is a way to lock buttons on the CS.
    Jul 2018
    San Diego, CA
    27
    I mean... i guess locking any button that could affect what's in program would suffice, but I figure it'd be easier to just lock the whole surface down.
    19,480
    I would expect a network-connected CS to reconnect without exiting the session if the connection is interrupted. If that isn't so, please enter a fully detailed bug report.
    Jun 2018
    Columbus, OH
    9
    I'd consider building a hard case that covers the CS so that nothing can be changed. maybe even clear plastic to visually check ststus...
    John Alexander
    TriCaster Mini (HDMI)
    Spark Connect
    Sony HXR-NX5R
    Sony NX-5U
    Canon XF105
    4,230
    I use one of these for keeping people from touching ours....
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    Jul 2018
    San Diego, CA
    27
    Spoken like a true Texan.
    Apr 2008
    Racine
    1,673
    "live replays rolling" - you mean from DDR for instance? In Output Config, you can change MIX1 for example from PROG to DDR1 and then regardless of what switcher buttons are pushed, MIX1/OUT1 will be DEDICATED to showing only DDR1. Setting an OUT to any SOURCE can be recorded and saved as a MACRO. So create one macro to switch output to DDR1 and another to switch it back to PROG again. And macros can be programmed to your CS. Or put a PAUSE in the macro and after the pause it goes back to PROG, whatever. Of course you could also do this manually with the mouse as well. Unless someone actually stops the DDR playback, no other buttons they bump should have any effect on the DDR playout.
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jul 2018
    San Diego, CA
    27
    Happy to. Please define "fully detailed".
    Quote Originally Posted by 090 View Post
    A step by step with all of the versions numbers of your products and how they are connected.
    19,480
    In case it helps:QA tells me that on busy networks, establishing a new IP address can take upwards of a minute, but in any case should not require you to exit live.
    Jul 2018
    San Diego, CA
    27
    Ah! Interesting. Perhaps we're just not waiting long enough. I shall test it again. Thanks!
