Results 1 to 11 of 11
Thread: GPS data to mesh
    Near Beaverton, OR
    1,621
    GPS data to mesh
    I'm looking for a script or utility that can take GPS data (extracted from GoPro footage) into CVS format, and convert that to point or polychain data I guess for Modeler.
    I found a utility that extracts the GoPro info to CSV format. The GoPro data is Milliseconds, Latitude, Longitude, and Altitude. I "test" using GoogleEarth Pro which is getting the position but a bit iffy on the altitude. Shouldn't matter for Modeler I'd think.
    The only thing I've found so far on the Lightwave end is Mike Greens script MG_Import_CSV_Motion_GN.ls, but it's for creating a motion path. I think there's someway to then take that into Modeler, so perhaps that's a start.
    What I'm looking to get is just a coarse terrain mesh but reasonably accurate. Over half this property is covered in trees so Google Earth isn't of much help actually seeing the ground no matter what gets turned off in its UI.
    Thanks.
    The Big Apexx System:
    64GB DDR4-2666
    7,993
    TrueArt's Node Library
    http://nodelibrary.trueart.eu
    has CSV Reader node.
    You can specify which column(s) and row(s) you are interested in,
    and use it in Displacement Node Editor to move single point-cloud accordingly to CSV data.
    Then save transformed object and load in Modeler.
    England
    5,922
    Truart, didn't the CSV node used to be free?
    Desk Work:
    Desk Home:
    7,993
    Pre-2019 version was free.
    Super Member inkpen3d's Avatar
    Jun 2003
    amersham, Buckinghamshire, UK
    776
    What about USGS data? This video https://vimeo.com/322225534 (at about 1 hour and 3 minute in) spends a few minutes explaining in general terms how to download and extract terrain data from the USGS web site.
    This page explains in detail how to get the data: https://www.usgs.gov/faqs/where-can-...elevation-data
    And there's even an old thread on these forums about using such data: https://forums.newtek.com/archive/in.../t-142197.html
    Of course, there's always a possibility that the USGS data might not be high enough resolution for your purposes.
    iemedia solutions:
    Web Site
    YouTube Channel
    Scavengers SciFi novel:
    Amazon UK
    Amazon USA
    England
    5,922
    Hye TruArt...
    That CSV Reader node you show above... is that in your "TrueArt's Node Library"?
    It doesn't seem to be mentioned in your website at all, but wanted to make sure it was in there AND works with LightWave 2019?
    Please could you confirm this?
    Desk Work:
    Desk Home:
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,146
    Its relevantly easy to format a list of 3D coordinates to conform to the .OBJ file spec in a spread sheet. (https://en.wikipedia.org/wiki/Wavefront_.obj_file) The attached spread sheet shows how to format a list of vertices into a 2 point poly chain. Save it as a text file with the .OBJ extension and you can open it in Modeler.
    Attached Files Attached Files
    7,993
    Yes. It is working in LW 2019. I just checked it.
    England
    5,922
    Cool, thanks... Will probably buy this then. ��
    Desk Work:
    Desk Home:
    7,993
    You need to send me mail or PM after purchase, because PayPal no longer sends mails automatically to my domain.
    England
    5,922
    Ordered! Thank you!
    Desk Work:
    Desk Home:
