Thread: Bump map notworking as expected
    Apr 2016
    Barcelona, Spain
    577
    Hi all, have reported this on june 2018, and still without a solution.
    I've seen that bump maps have some sort of offset that makes me impossible to use my library's bump maps.
    This is an example of the problem:
    Have found a workaround, using the bump layer. But still I'm waiting the solution from the devs.
    This is for your information, just in case anyone have this problem, but please devs, take care of this.
    LWB-4088
    Best regards.
    English is not my native language so please be patient.
    Salvador Ureņa
    http://urenasalvador.wixsite.com/portfolio
    7,993
    How about color space settings in Image Editor?
    Normal and bump maps are vulnerable.
    Apr 2016
    Barcelona, Spain
    577
    Bump map as linear.
    Salvador Ureņa
    Are you tried reduce the bump intensity less than 100% in the node image 2?
    Apr 2016
    Barcelona, Spain
    577
    Yes, until is barey noticeable.
    Salvador Ureņa
    Registered User MarkAH's Avatar
    Feb 2008
    Green Valley, AZ
    66
    I like this. Very interesting question, so I did some experiments.
    First consulting the documentation:
    "Bump Layer
    The interface for the Bump Layer node is the same as that for a standard Lightwave texture layer.
    The only difference here is that the background for the texture is available as a connectable Bump
    input and an Alpha output is available as a scalar, based on the last texture layer’s result."
    I thought, 'background ?', how the #### does this node determine the background of an image?
    And beside that I can't make much sense of this paragraph.
    So I found a pair of inverse bump maps in my library and set up a test like you have there.
    Now these images have a light grey, kind of noisy area which I figured to be the background.
    And I get the same results. Where the negative image is loaded into the Bump Layer node
    that noisy background is ignored and does not affect the surface.
    But where it is loaded into a 2D image node and the bump output is used the noise significantly
    contributes to the surface.
    In the 2D image node 'Bump' is set to 100% and in the Bump Layer node 'Texture Amplitude' is set
    to 1.0, which I figure is equivalent.
    So, you discovered something useful. There is probably nothing wrong. The Bump Layer just has
    the amazing ability to sort out what is the background and ignore it.
    Very cool! Thanks for the tip.
