Page 1 of 4 123 ... LastLast
Results 1 to 15 of 46
Thread: GPU / CPU Denoiser Test in LW 2019
    Netherlands
    5,560
    HI all,
    I didn't expect much from the new GPU denoiser that was added in 2019, since all the denoisers LW has had (and most other tools I know) have been pretty dismal to the point of completely useless. But I thought to give it a try when I read up that it was based on Deep Learning and AI instead of the traditional approach. And boy, does it matter.
    Summary conclusion of result:
    • GPU Denoiser: Fan bleeding tastic. In my test I could cut render times by 75% and have almost exactly the same results as trying to solve noise with denoiser off. This means you can assign sample calculations to other areas such as AA instead, or simple, just sit there with the win of your 75% lower render time.
    • CPU Denoiser: Still unbearable, and pretty much useless. Also its convoluted use by having to turn it on in two different places in the UI is aggravating.
    No Denoiser
    GPU Denoiser
    CPU Denoiser
    Denoise using extra samples only
    Just for comparison's sake, below is a render with an attempt to denoise using extra samples to an acceptable level. This bumped the MC samples to 3 from 1, and the AA to 6-26 (instead of 4-8). Render time of this was 12m40 seconds. Render time of the above was 3m05s, including denoise for both GPU and CPU. That is a more than 75% gain, and the result is even less noise.
ID:	144219   Click image for larger version.
ID:	144220   Click image for larger version.
ID:	144221   Click image for larger version.
    In my opinion user should have option to turn off GPU denoiser on chosen buffer, especially on raw rgb (with result in final render).
    Examples with GPU denoiser OFF/ON:
Name:	Grid denoiser OFF.png
ID:	144223   Click image for larger version.
Name:	Grid denoiser ON.png
    Netherlands
    5,560
    Quote Originally Posted by MarcusM View Post
    Yes that may really help. I also noticed small details disappearing. That would also leave the edge shaded render lines sharp. Have you sent that in as a feature request or bug report?
    Still though, amazing results.
    Malmö, SWEDEN
    7,727
    It works like that allready?
    - - - Updated - - -
    Senior Technical Supervisor
    Cinematics Department
    Massive - A Ubisoft Studio
    AMD Ryzen Threadripper 3990X (64 cores/ 128 threads)
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    Quote Originally Posted by Exception View Post
    I did not send feature request. For sure developers know about that things and maybe this is not possible. Your CPU denoiser test have propably turned off nice option Poly Normal Tolerance.
    Image filter plugin PSD Export should have all new buffers built in and then in PS user could use Surface Blur tool I made test with PSD Export and it export only linear color, not sRGB. No matter what Layout color space I choose. Is it a bug?
    BTW I would like to see more things for game dev and there is many things to add in that field.
    Quote Originally Posted by Cageman View Post
    This is just small test how GPU denoiser treat details on texture.
    To do this, we'd need to have internal compositing in LW, Currently the buffers system works by performing the render, and extracting the buffers from it, not the other way round. Not that it wouldn't be cool or desirable, but that's quite a lot of extra work.
    Aug 2016
    a place
    2,364
    be cool if the densoiser could be called from a node, then dpont kit could be used to filter per render channel.
    of course, having a mask there that filtered all but specified would be the go.
    chat elsewhere about the merits of inversion within a node. perfect example.
    i think node based render pass setup would be most intuitive to the end user, too.
    oh, here we go, something similar mentioned here https://forums.newtek.com/showthread...DPont-Denoiser
    geo messy madno's Avatar
    Feb 2009
    Germany
    848
    An evening mood test with pure BF GI and the new LW 2019 sky.
    In this case the denoiser works nice for uniform areas, but it has a hard time to keep the details.
    The attached render took 2h someting on a dual Xeon 32 thread machine and used 400 BF samples. Unfortunately the details on the plank tectures and the lower part of the curtains are still gone in some areas (zoom in).
    But, like I understood it, indoor GI is always a challange not only in LW.
    (had not enabled Despike - maybe that would have cured the fireflies).
    for DeNoise in 2019, also see this Gerardo thread >
    https://forums.newtek.com/showthread...11#post1560511
    Feb 2006
    england
    1,401
    Quote Originally Posted by madno View Post
    you might want to purchase the rebilhill tutorials, one of the courses is setting up this scene to render in a few mins, his tutorials will teach you a lot about rendering in general, lots of hidden tips throughout,
    - - - Updated - - -
    Feb 2009
    Germany
    848
    Do you have an example render of this scene (was posted some time ago to download) rendered in a few miutes? I am in the stage of finding other solutions but would be happy to get a hint that LW can do it.
    Nov 2003
    jersey
    5,792
    This animated shot of the scene...
    https://www.youtube.com/watch?v=s61U0iczvkw&t=1m52s
    was about 25mins/frame on 6 thread phenomII.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Apr 2011
    French
    29
    Wink
    Hello RebelHill,
    I see two errors important enough even if it is to save time to render.
    The problem "no detail", I also have on all the tests that I did and impossible to have the details even with large parameter of GI.
    This is one of the problems on the lightwave rendering engine ..
    Malmö, SWEDEN
    7,727
    Quote Originally Posted by Tobian View Post
    GPU/CPU denoiser are filters. You can tell wich buffer should recieve Noise filters already.
    Or, are we seeing a bug where this checkbox doesn't work?
    EDIT: Or, are some users still believing that LW "beauty pass" are a composite of internal buffers? If that is the case... Yes, that is not possible now. I havn't heard of any renders that works like that though...
    64GB Ram
    Quadro 620
    Windows 10 Pro x64
    "no detail"
    yes, LW engine can be like that as far as i know, especially with interpolated.
    as for the glass reflection, i didn't notice anything, could you elaborate?
