Results 1 to 10 of 10
Thread: LW 2019 Smoothing groups
    Super Member kolby's Avatar
    Aug 2004
    CZ, EU
    429
    I have a question about the smoothing groups. I've created several smoothing groups on my model but in the Layout my model is without any smoothing ? Did I miss something ?
    System info: CPU: Ryzen 9 3950X RAM: 32GB DDR4/3200MHz MB: Asus Prime X570-P GFX: Asus GTX 750 Ti / 2GB OS: Win10, LW2019x64
    I tested this and it is interesting.
    Default material in Modeler is Principled BSDF with turned off smoothing. When you set smoothing groups in Modeler you see result but smoothing in surface is still turned off.
    When you save object and send to Layout then like you wrote, smoothing groups are not visible. You must turn on smoothing in surface. In my opinion you can send a bug report. Layout should see smoothing groups like Modeler.
    Aug 2004
    CZ, EU
    429
    If you turn on smoothing in surface, smoothing groups are visible in OGL, but smoothing in the rendered image is wrong.
    Bug report sent.
    It's been reported (by me and several others from what i can see in the system).
    So yes, it's a BUG.
    RAM-Studio
    WS - Dual Xeon E5-2698v4/128GB/Win10x64/4xRTX 2080Ti
    So yes, it's a BUG.
    RAM-Studio
    Jan 2005
    Germany
    164
    It is still broken in 2019.0.3, right?
    LightWave 3D 2019 (Win64)
    Aug 2010
    Kernow
    2,094
    Quote Originally Posted by SaT View Post
    It works here?
    Attached Files Attached Files
    Jan 2005
    Germany
    164
    Thanks for your test scene. Now I know why it did not work for me. I always did not check the smoothing option in the Surface Editor when using Smoothing Groups because the Smoothing Threshold is not used for this.
    Aug 2010
    Kernow
    2,094
    Yes. It's a strange thing, but if you have smoothing groups then you don't need a smoothing threshold.
    Cheers!
    San Jose, CA
    6,981
    Quote Originally Posted by XswampyX View Post
    That's really a bug, though. If there really needs to be a global enable/disable to smoothing groups' effects, it should exist as an independent, object-level property. Having surface-scope properties controlling object-scope attributes just creates a bunch of odd corner cases (read as: bugs), as well as import/export inconsistencies.
    At the very least, if per-surface Smoothing must be enabled to allow smoothing groups' effects, then that control ought to be auto-enabled for all surfaces applied to objects' geometry where active smoothing groups are present. Having it work otherwise just creates confusion and problems.
    John W.
