Thread: TriCaster Mini only shows screen saver
    Registered User Flexmedia.tv's Avatar
    Sep 2015
    Perrinton, MI
    34
    Hello Folks,
    I have a TriCaster Mini I bought 2 years ago. I havenít used it since. (Diagnosed with cancer but better now!) I havenít used it since but today I hooked up two Go Pros, launched TriCaster. TriCaster never launches but goes into a splash screen. My only option is to log out or power off. I donít see the cameras or home screen. Iím thinking itís because I havenít used it in two years. Anybody have any suggestions for me?
    Thanks!
    Art
    Choir Director, Maple Rapids, MI
    Tricaster Mini SDI
    HPX 170P, HPX 300P
    May 2004
    Vancouver, WA
    1,584
    Which port do you have your monitor plugged into? You might be in one of the ports that aren't the primary ones for the user interface. I think on the Minis you need to be up on the HDMI or DVI ports that are away and separate from the main motherboard ports near the USB and all that. The ones on the motherboard are for "display" like extra PGM monitors and not the user interface.
    I'm glad you are doing better and back into it.
    Kris
    Replay: 3Play 820
    Cameras: Sony NX5
    Sep 2015
    Perrinton, MI
    34
    Hey Kris,
    I have it in the HDMI slot but it does the same without the external monitor. Thank you for the quick reply,
    Art
    Tricaster Mini SDI
    HPX 170P, HPX 300P
    May 2004
    Vancouver, WA
    1,584
    Make sure it is the correct HDMI connector. See the attachment - not in the red one, only in the green one.
    Kris
    Replay: 3Play 820
    Cameras: Sony NX5
    I describe it as "use the HDMI/DVI ports directly below the power connector."
    19,560
    Or just the one labeled "Interface" ...
    Sep 2015
    Perrinton, MI
    34
    That was it. I had it in the display port. Thanks! Stay tuned and wish me luck!
    Art
    Tricaster Mini SDI
    HPX 170P, HPX 300P
