Results 1 to 12 of 12
Thread: LWCAD and LW2019 install issues
Hybrid View
    I should update my Avatar Verlon's Avatar
    Earth
    2,356
    I'm not posting under support because I do not believe this to be a Lightwave bug, at least not in the normal sense.
    I installed LW2019, and registered it. - on macOS Mojave running on a Early 2018 MB Pro.
    As per usual, this is followed immediately by installing LWCAD (5.51) and setting up the menu branches.
    Then I open LW to register LWCAD
    None of the buttons work. There is no "You must register LWCAD" or other window. Even the LWCAD Options button doesn't do anything.
    Ok, went back and re-downloaded LWCAD. I manually added the plugins. Same thing. I tried various remove and reinstalls of the plugin, but nothing. At least one other user was having similar issues, but not sure whether that was Mac or PC, on the LWCAD Forums.
    Has anyone else had this, and, if so, how did they get around it.
    Yes, I posted on the LWCAD forums also, but sold my patience to buy more rum!
    Verlon Smith
    http://www.youtube.com/watch?v=g4i3XnbEKBw&feature=plcp - shameless prommotion for my daughter's horror (by 4 year old standards) story.
    5,922
    Could it be an issue with the menu branches?
    Have you tried just adding the LWCAD tools to a menu branch that you've created yourself? Would be interesting to see if that works, or doesn't.
    Desk Work:
    Desk Home:
    Earth
    2,356
    Thanks for the response.
    I haven’t tried that, but the plugins are not showing under the “additional” menu to run without using the branches. This is part of them not working, I think. That said, they show as installed under “Edit Plugins.”
    I tried adding the plugins directly from my working 2018 directory, but this did not alter the result.
    Verlon Smith
    Murcia, Spain
    3,127
    All fine here with the latest version on windows. Sorry cant be of much help with Mac issues. Have you contacted Viktor because i know he is planning a couple of updates this year before LWCad 2020 comes out.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
    ack ack Markc's Avatar
    1,449
    I have LWCad 5.51 running in LW2019.0 in HS.
    Maybe it's the same Mojave issue that LW2018 had with the buttons.
    Sorry wrong answer ...
    Ryzen Threadripper 2990WX 32 Cores - 64 Threads / 2 x GTX 1080 + 1 GTX 1070 / Windows 10 x64 / 64 Go Ram / LW2019 & Softimage user
    Earth
    2,356
    And I fixed it!
    Uninstalled LW2019 (everything).
    Reinstalled LW2019.
    Added LWCAD from LAYOUT instead of Modeler.
    Everything works. I cannot fathom why this would make the least bit of difference, but it did. All of the files are the exact same as before.
    Verlon Smith
    Super Duper Member kopperdrake's Avatar
    Mar 2004
    Derbyshire, UK
    3,147
    Found my answer on the LWCAD forum - should've looked harder before posting here, but incase there are other muppets who stumble through life with their eyes half-shut, here's the answer:
    You need to manually install it.
    Doh!
    - web: http://www.albino-igil.co.uk - 2D/3D Design Studio -
    - PC Spec: Intel i9-7940X @3.1GHz | 64Gb | 2 x GeForce GTX 1080 Ti 11Gb | Windows 10 Pro -
    Registered User calilifestyle's Avatar
    Jun 2006
    cali, Santa Clarita
    1,562
    Blog Entries
    4
    Quote Originally Posted by kopperdrake View Post
    Doh!
    Uncalled for
    Ell no 'ta enamora' de mi, yo tampoco
    Pleased to meet you. Oedo 808's Avatar
    London
    1,560
    Yeah, there was no need at all to insult the muppets
    (calilifestyle, check his previous post for context)
    Sentenced to 310 years for crimes against modelling and rendering.
    Earth
    2,356
    Well, I have long griped about the lack of changes to Modeler. Now I have the most significant change to Modeler since LW6: LWCAD isn't working.
    I've added uninstalling and reinstalling LW and LWCAD, and I've reached out to Viktor as well.
    I guess the bright side to all the focus on Layout is that I can use Modeler 2018 without missing out on new features.
    Verlon Smith
    Mar 2004
    Derbyshire, UK
    3,147
    I've a quick question about this. I've got LWCAD 2018 installed in LW2018 okay, but when I run the LWCAD 2018.1 installer, it isn't finding my installation of LW2019.0.1 - anyone any ideas?
