Results 1 to 13 of 13
Thread: Updated Nvidia Driver Now TriCaster Won't Start
    Registered User stanarthur's Avatar
    Jun 2013
    Florida
    59
    I'm getting a GPU error, "Unable to verify video drivers" and it opens the Nvidia driver download page I just previously used to download and install the Jan15, 2019 driver.
    TriCaster Mini SDI Advanced Edition 2 Build 5-1-180323C
    Talkshow
    Apr 2008
    Racine
    1,673
    Go back to a version 399 graphics driver for now, that should work
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jun 2013
    Florida
    59
    It took some doing because I had done a clean install that wiped out v399. I eventually got it back, though.
    Talkshow
    Apr 2008
    Racine
    1,673
    Quote Originally Posted by stanarthur View Post
    Not sure what that means, just download graphics drivers from nvidia.com as needed
    Jeff Pulera
    nVidia has released so many driver versions since 399, that it isn't on the list anymore when you search for it.
    Latest versions of TriCaster AE2 (and AE3) are compatible with nVidia 400+ driver versions.
    Registered User rsilva's Avatar
    Apr 2016
    Lisboa
    43
    And about TC1 with last firmware (7-0-190130). What's the recommended nvidia driver version?
    If the TC1 isn't telling you to update, then you are on a recommended version.
    Sep 2014
    London
    102
    Trying to update my drivers for the AE3 Checker, 399 is too old for the checker, 418 is too new for the Tricaster I'm on 5-1-180323C which is pretty old so that's probably why. Good news is any version newer than 399 seems to pass the checks.
    Bloomington, IN
    1,626
    You can download older (i.e. v399.x) nvidia drivers here: https://www.nvidia.com/Download/Find.aspx?lang=en-us
    -Jeff
    My TriCaster Blog
    TriCaster Tally Lights
    Just to make it easier, here are direct links to the 399 drivers for both Windows 10 and Windows 7, using the link that Jeff posted above.
    Windows 7 (Mini, 410, 460, 860, 8000 systems)
    https://www.nvidia.com/download/driv...x/137725/en-us
    Windows 10 (TC1, VMC1, 3P1 systems)
    https://www.nvidia.com/download/driv...x/137727/en-us
    Nov 2012
    Worcester, UK
    160
    I also had nVidea drivers V 399 on my Mini and to check compatibility I have just installed drivers 418.91 as per Kanes instructions above.
    Although the test program re AE3 has confirmed my machine will run it, when I return back to AE2 I also get 'Unable to verify video drivers' error.
    So it would appear that my version of AE2 isn't compatible with the latest drivers.
    So can I ask where can I get the latest version of AE2 which IS compatible with my machine (no links on the website) and the latest nVidea 4** drivers, OR is your statement above incorrect?
    It should be the AE2 v5-1-181220 that works. You can download it from here.
    https://www.newtek.com/downloads/#tricaster
    Jun 2017
    Lock Haven, PA
    14
    I needed to revive this thread in hopes that I can get this fixed. I contacted support today about an issue that recently arose (some displays black out and I lose digital audio in until I reboot the system) and like all loser tech support I was told I had to update my NewTek software and then update the video drivers before they could do any real support diagnoses. Since doing that I can no longer operate the TriCaster. I get the same error message as the OP. I've tried dozens of different Nvidia drivers (and of course the latest one) and all I get is the same message. So far tech support has not returned any more of my emails, even though I am remaining calm and collective. But things are coming to a head now. The system is down completely. The studio is useless. Nothing works. I need a solution fast.
    ticket # 391540
