Thread: Displace ploys along normals without bending or smoothing
    Hi All!
    Not sure if i worded my title line correctly, so here's the skinny... I have a plane of polys that I would like to cascade down to a final position. I could separate them all out to individual object layers and control then with 3 or 4 different techniques, but I just don't want to break them out like that (there's al lot!).
    A standard texture displacement causes them to distort as they move (the shape contains explicit non-welded polys but their sides are coincident in space). I would ideally like the polys to move in a cascading manner without changing shape.
    Thoughts?
    Cheers
    Jeff
    Jan 2005
    Colorado Springs
    1,862
    Is this in Layout for an animation or in Modeler for a final geometry or morph? Also, what version of LW.
    mTp
    Aug 2014
    South Bend, Indiana
    433
    You could try DP Kit Part Move.
    ok... here's the embarrassing part..
    In layout.... version 9...
    I know I know... I power it with a mule on a treadmill ok?
    Jan 2005
    Colorado Springs
    1,862
    PartMove is available natively in LW2018 (and I assume later). Here's a prior thread which gives an example of offsetting an array of square tiles with a black&white animation:
    https://forums.newtek.com/showthread...on-Texture-How
    The part (tile) offset can be run from almost any sort of Scalar input.
    mTp
    Jan 2005
    Colorado Springs
    1,862
    OK. For LW V9, I think you could use Point Clone Plus to create the base morph and a morph for the final position of the plane of polygons, then use MorphMixer to do the transition. It also looks like DP Kit is available for version 9:
    http://dpont.pagesperso-orange.fr/pl...l_Nodes_2.html
    but I don't know if DP Kit Part move was available then.
    mTp
    Registered User Hulk's Avatar
    Sep 2003
    10X,185Y,35Z
    47
    Try this nodal setup Tiles.zip
    Attached Files Attached Files
