Thread: NDIlib_routing_create returning NULL??
    Registered User roddyp's Avatar
    Sep 2017
    UK
    29
    We've had a problem reported with one of our apps, and a check through our logs shows that the NDIlib_routing_create API call is returning NULL, rather than an instance.
    I don't yet have any details of the parameters being passed, but a heads-up on the possible causes of this would be useful.
    I'd expect using a blank name, or the same output name twice would do it - but are there any other obvious failure modes?
    Software Engineer
    Jul 2006
    San Antonio, TX
    12
    The main cause would be centered around the name: you've specified a name but the name is in use already. Another would be it failed to find a port number to successfully bind to. This is less likely.
    Brian
    Sep 2017
    UK
    29
    Quote Originally Posted by brianbrice View Post
    Thanks very much, that's helpful.
    It would be very handy if a specific error code could be returned or made available via a getLastError function.
