Results 1 to 15 of 29
Thread: How do I revert back to a previous install.
    Jul 2013
    Kansas
    470
    I seem be having issues with my sound unless it is a coincidence with the new update for AE 2 on my mini. My sound is very poor when I download it to edit. It sounds good in the speakers, and even the phone jack coming out of the mini but when I do a session and download it to a flash drive and then try to edit it on a computer, it sounds crappy. It never did this until I did the new update. Anyone else have this issue?
    Aug 2016
    USA
    560
    I know that it's a bit late for this. I always make a backup of my current install onto an external drive, especially before I do an update.
    Then if there is any issue I have an easy way to get right back to the last working system configuration.
    Jul 2013
    Kansas
    470
    Yeah, I should have. I found the issue is only in my h.264 because when I record in the .mov it sounds fine. What could be the cause?
    Aug 2016
    USA
    560
    Bad level setting? Did you try and just record audio as well and see what that sounds like?
    Apr 2008
    Racine
    1,673
    When updating TriCaster, manually go to Newtek.com and download the latest software (that you can install later). When it asks, say you only want to DOWNLOAD, not install. Once downloaded, copy download folder over to another drive other than C: since C: would get wiped with a Restore. NAME the download folder the same as the software version. In this way, you will have your own collection of TriCaster software versions on hand. You can choose to delete the older ones as time goes on, but if you at least have the last couple of versions it gives you option. Even if you might need to RESTORE, then apply software update.
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jul 2013
    Kansas
    470
    The levels are fine. When I record in .mov it is fine and sounds good. I have not changed any levels at all. Inf fact when recorded in h.264 the levels are very low. I have tried all sorts of things but the h.264 just has gone crazy.
    I'd contact support. Perhaps they know of a solution or can help you get a previous software version if needed.
    Jul 2013
    Kansas
    470
    I did. They will talk it over and see what they think. I sent them the audio of the h.264 stream.
    19,793
    As far as I can recall, nothing has changed with respect to audio levels for quite a while. I think you mentioned you noticed the problem after an update. Was this a major update, or have you been keeping up? AE2 has been out for quite a long time.
    Jul 2013
    Kansas
    470
    No, not a major update. I went from Rev 5-1-181112 (November 12, 2018) to Rev 5-1-181220 (December 20, 2018)
    Jul 2013
    Kansas
    470
    Can anyone explain why support wants me to loop my mini? I take a perfectly good video that had been in the ddr for sometime and record and when I record on h.264 it has weird sounds in the audio. I record from an outside source into h.264 and the same thing happens. I take a Newtek premade video that was already in the mini and play and record it in h.264 and the same distorted or weird noise is in the audio. I repeat the same process with .mov and it sounds the way it should.
    What would looping my mini change with any of that?
    Aug 2016
    USA
    560
    No Offense to support, but that appears to be a part of every troubleshooting procedure they have. You get asked to do it, no matter if it makes sense or not.
    Apr 2008
    Racine
    1,673
    Just for kicks, update both the nVidia graphics driver and the Intel graphics driver.
    Jeff
    Jeff Pulera
    19,793
    Quote Originally Posted by ingeborgdot View Post
    So as not to confuse the issue, I would pick the simplest case - perhaps the last one, record two short clips (using the latest software) that illustrate the issue clearly, and submit a bug case.
    Jul 2013
    Kansas
    470
    How do I update the intel graphics driver again? I have done it but have forgotten. I'm going to go try now and see if I remember. Thanks.
