Results 1 to 8 of 8
Thread: Lightwave 11.6 compatible instancing
    May the sauce be with you starbase1's Avatar
    London, UK
    5,663
    Hi All,
    I've tried google and I've tried searching these forums but...#
    I'm trying to get the hang of instancing using LW 11.6#
    I've done a grid, I've done a ring, now I want a specific arrangement, and I'm not having much luck.
    Any pointers to suitable beginners tutorials?
    (I'm actually after an even square array, but confined to a circle, so evenly spaced on X and Y but forming a disk.)
    Thanks,
    Nick
    Specialist subjects: Unflown space projects, and the space program of the Soviet Union.
    My main Web site
    Jan 2005
    Colorado Springs
    1,875
    I'd create a disc of the appropriate size in Modeler, use Julienne to slice it up into X and Z chunks, use the Statistics panel to delete any points that are only contained in one polygon (i.e. those points originally on the circumference of the disc), then use Merge to merge points on the circumference so Instances aren't too close together (ended up using Manual of 20cm on the attached disc). Use "k" to kill the polygons, leaving only the point array.
    Sample LW11.6 scene / object attached. The Instancer is set to type of Points and the Max Points flag is set to place an instance at each point
    mTp
    Attached Files Attached Files
    8,347
    Quote Originally Posted by starbase1 View Post
    Make point cloud in Modeler and then use them as source.
    I showed how to spray instances in my video of SprayBgPoints. You can use it as tutorial of instancing in any LW.
    Special option of SprayBgPoints disallows them for overlapping.
    https://www.youtube.com/watch?v=P6p-Cm_PFyc
    8,347
    You can leave single-point polygons, even give them surface name. In LW 2015.0.3 and LW 2018.x (at least) there are options to filter instances by polygon's surface name. Type: Polygons, Surface Name: [pick one]
    something like this ?
    Aug 2010
    Kernow
    2,095
    Quote Originally Posted by tischbein3 View Post
    Very good!
    How about...
    London, UK
    5,663
    Excellent, thanks for an example!
    My main Web site
    London, UK
    5,663
    Thanks to all for the help, I now have a huge hexagonal array of solar power sats, which I unfortunately can't share yet.
    I'll be following up on the other tutorials, this definitely looks like a powerful technique!
    My main Web site
