Thread: 2018 some minor problems
    May 2008
    Iowa
    43
    1. Heat shrink seems broken. Using Heat Shrink to drop a segmented flat poly over another poly to match a landscape (for instance) causes all sorts of errors. I go back to LW 2015 to do the same operation successfully.
    2. On mac platform. going to load object or image if you hit the space bar to preview that image or dragging a folder over to the sidebar drops that operation. The folder for instance is moved but you have to do the load operation again. This works fine in all previous versions of Lightwave. This is not a huge problem buy annoying especially if it drops during the loading of a missing image at startup of scene.
    San Jose, CA
    6,897
    You should report these using the Feedback app (installed in same dir as the LW apps).
    John W.
    Pessac
    5,180
    Yes, definitely report, but consider rewording 2. I have no idea what you meant. I don't use a Mac as my principal platform, but even so.
    B
    LightWave 3D Trial Edition
    San Jose, CA
    6,897
    @hansen: Might want to check if you have St. Claire Software's DefaultFolderX installed. If so, you'll want to set up exclusions for LW2018 apps, as there are still compat. issues.
    John W.
    May 2003
    Ireland
    153
    Hello Digital Confusion doesn't work any more. ticket LWB-4089
