Results 1 to 15 of 18
Thread: how to calculate automatically the linear length
    Hi guys, I need to know if there's a free plug-in, or a simple way to calculate the total linear measurement of these elements. thankyou
Name:	telaiox misure.jpg
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,563
    Modeler has the measure tool (detail -> measure), which would work for single items.
    I'm guessing that you want to total the lengths of all the pieces, probably for materials estimation.
    I don't know of anything off hand, even in LWCAD. I could probably script something to do the job, but have very little time right now.
    Since there appears to be four groups of different lengths, I would get the length of 1 item from each group, then multiply it by the number in each group. repeat for each group, then add them up. Add a cutting allowance x the total number of pieces (3mm - 10mm, depending on material and cutting method), and you've got your total length.
    My Scripts for Lightwave
    yes, no script i'm aware of does this.  (unfortunately)
    probably more common for CAD apps.
    Kryselin's method is the way to go i believe.
    (or export the model to another app with the ability)
    ...or perhaps better, use another app, like ViaCad
    https://www.youtube.com/watch?v=_XaRH2XNqWM
    and very tedious for me to count the individual pieces and add the lengths .... it would really need a script to be able to automate. I realize very complex iron frames, where I lose time to calculate the length of the "iron" used by hand... sorry for my english...
    16,168
    Quote Originally Posted by luciano View Post
    Maybe this could work a bit efficient, if you have the rods as one surface? or just go to send connected to layers, delete all layers that arent the rods...you are then left with a layer per rod (if these rods is one connected segment that is and not welded to other segments)
    Then you go through each rod layer and use absolut size..that avoids measuring with the measure tool, you should have a display of the lenghth etc on each rod.
    As I can see the rods are green surface..and you may be able to use select by surface, invert and delete all other polygons initially, which leaves you with the rods only, then use connected to layers, and you have each segment ready to evaluate with absolute size ..whithout having to manually pick start and end for measuring.
    Feb 2009
    Prescott, IA
    1,563
    A quick question : Are all those pieces connected together in the model, or all they all seperate? As in, is each tube separate from the others?
    I have an idea that might work, but each tube needs to be separate from the others...
    each tube are separatefrom the others... not are weld
    Feb 2009
    Prescott, IA
    1,563
    Ok, then my idea will work.
    I'm curious
    Feb 2009
    Prescott, IA
    1,563
    It's a scripting Idea. Since each rod is a separate mesh, I can select each "tube", compute the dimensions, store the results, and generate a report.
    If you had extended everything out, and it was all a single mesh, this would be much more complicated.
    Aug 2006
    Eureka, CA
    7,003
    Would a uv map help in getting the total area?
    shrox www.shrox.com
    Heavy Metal Landing
    not much, interesting suggestion, but would be lots of manual work i believe, so might as well do it manually in 3D view
    best way is selecting polys, then using Absolute Size.
    slow, but works correct, and a straight forward approach.
    16,168
    Sort of what I suggested, though with the difference of using connected to layers, so you do not have to select connected pieces, just run Absolute size on each layer and insert in excel or any other note app if needed.
    I Wish there was a script or something to do a one single mouse click to select connected.
    Kryslin may have something going if he can make the script of calculating each segment ..then return with a report including all segments individual length or full scale .
