Results 16 to 30 of 36
Thread: Discussing PTZ UI
    Registered User rsilva's Avatar
    Apr 2016
    Lisboa
    32
    Just to mention it, so it's not something you've not considered - don't overlook the fact that there's now a PTZ page in LivePanel under Premium Access that would give you an outboard way to trigger presets for whichever camera is selected on the Preview row.
    I totally understand the benefits of the LivePanel, and they are huge! We have five TC-1 units all over our conference rooms and auditoriums. Three of these space are facing space issues, so get an extra iPad or Laptop for LivePanel operation is not a option. Please, take care this concern in next updates and bring back the PTZ tab. No problem if it will be a paid feature, but try to understand my point of view, I believe that I'm not alone in this thoughts.
    19,396
    Quote Originally Posted by rsilva View Post
    Not to imply I'm unsympathetic - certainly we want to make our customers happy to the degree we can do that - but I'm still waiting for a good explanation of how the 7-0 implementation actually makes things harder/worse. I say this in complete sincerity, not trying to be provocative - I really want a good case for why it was better before ... even more than one case if possible.
    Apr 2016
    Lisboa
    32
    (...) ... even more than one case if possible.
    I cannot find more than one. But I'll try to expose "the big one".
    Just to clarify, in my opinion and all my others colleagues as well, the 7-0 don't make the "things harder/worse". Actually everything as been improved and it makes workflow better. Even the PTZ tilt movemente could be inverted, and that's perfect! The ONLY exeception is the PTZ TAB relocation. I'll try to explain the main reasons:
    1 - The 16 INPUT windows should be part of a PRE-PRODUCTION tasks. Clicking there every time to see the PTZ PRESETS makes me feel that I'm not "following the good practices". That menu should only be used to assign SOURCES and not to keep it open all the time. To be honest, in some cases is a bit "dangerous" beeing so close from the input changing windows.
    2 - The OLD PTZ TAB make the operators don't need to use the mouse all the time, and that's keep our attention for others things that really matter. We need to "refocus" every time it's necessary to call the INPUT window.
    3 - Sometimes we need to see DDR's all the time. Sometimes we need to see AUDIO MIXER all the time. Sometime we need to see PTZ PRESETS all the time (and now it's not possible anymore - or should I kept the INPUT window pop-up open all the time?) - In fact, sometimes when I have less PTZ CAMS available in my procution, I really need to keep the PTZ TAB open all the time (And just check the audiomixer, or DDR's if/when necessary).
    TY!
    19,396
    A few comments inline.
    This basically seems to say "I'm used to using the popup window to configure sources. I'm not used to using it to select PTZ presets." I get that it's a change, and changes always trigger a similar response ... but perhaps you might come to feel differently in time.
    I don't honestly think the source menu is so close to PTZ presets that clicking one presents any real danger of an inadvertently making a source menu selection.
    Well, actually you can't do anything in the old PTZ pane without the mouse. I do understand that it may take a little more mental 'focus', as you put it, though.
    On the other hand, now you can keep the DDR or Audio Mixer open all the time when that's what you want and still access your PTZ presets. So it's a trade off, neither all 'pro' nor all 'con'.
    I do really appreciate your feedback. I'm still interested in hearing any very compelling cases where the V2 PTZ implementation falls far short of its predecessor.
    Apr 2016
    Lisboa
    32
    I feel that we are playing a game where I have already exhausted all my arguments that could lead me to victory, but I'll insist again XD
    Adapting to something new is very easy when it's something exponentially better. For me it has been a difficult adaptation, I think I already figured it out, right?
    Maybe I have emphasized this "danger", and maybe not!
    I agree. That's why I and other users have already given some thoughts about moving to the perfect solution: A new PTZ TAB, as wide as AUDIO MIXER and with the function of FOLLOW PTZ PREVIEW. It becomes easy to immediately view the presets thumbnails without necessity of using mouse entirely. ALso, the entery PTZ TAB could be call by double tap PTZ SEL button too, following this philosophy: https://support.newtek.com/hc/en-us/...8-OPTIONS-MENU
    When neither all 'pro' nor all 'con', maybe a forum poll help to clarify... Just an idea!
    Asking that, you will always win. I can work with the V2 changes so in the end you're absolutely right. But is V2 the best solution that can be achieved? (the question remains)
    19,396
    Please don't imagine that I am merely trying to 'win' an argument, or justify the current implementation. When it comes to UI and workflow, there are many approaches, and there are always also passionate advocates who feel strongly about one approach or another. We recognize that every little change we make is going to annoy someone, and equally important, can often result in confusion.
    Each change you see, and countless potential changes that were rejected, go through many rounds of discussions just like this one internally and, at times, externally. And the process of continual evaluation and improvement doesn't end upon release. This is part of that process. So I don't actually have a dog in this fight, except to do my best to ensure we hear all the best arguments for various approaches before, during and after implementation.
    I can confidently say "No", it's not the best solution we can achieve. Broadly speaking, we are always working to improve things; more specifically in this instance, I mentioned very early on in this thread that we envisioned further changes. Naturally, any such changes will be made with consideration given to all feedback.
    BTW, this was the first post in which it has been clear that someone mentioned the PTZ tab as an adjunct to using the CS. Interesting...
    Jun 2012
    Europe
    204
    Interesting as well, how you want to convince everyone that this new "feature" is not as bad as it seems for quite a lot of users. Maybe we could reconsider if one day you tell us WHY this was designed that way.
    Yes, we can take the mouse and open another input setting pane , but we have to manually search for the gear , or do a right click or double left click . And then search for the other concerned input to set up another PTZ...
    Only one floating pane open at a time. During that time as someone already said, you're not in the working environment. during live prod, it's not good in my opinion, even if it's only a way of thinking.
    Having a list of sources aligned, and (even if we have to) from one to the other is much more clear and efficient than having to navigate through the whole UI just for that purpose.
    You tell about live panel PTZ feature. Why not, for sure it can help somehow, but now you have to buy an option for that.
    I mentionned very early during first presentations in June that many many users would not be happy with that new design, and got the answer Newtek would reconsider. Obviously they did not. They removed a very working feature.
    19,396
    Quote Originally Posted by doctorsunshine View Post
    I think you overlooked the first sentence in my post.
    On the other hand, previously a lot of users would often have had to find a mid-screen tab much smaller than an ISO monitor to click to switch away from the DDR (or Mixer) view to the PTZ tab, and then click a small thumbnail icon to select the specific camera they wanted to control - losing access to the DDR in the process. So on balance, I'd have to say no clear 'winner' on this point.
    If an obvious and compelling advantage for the former approach exists, I'd be just as pleased to hear it as anyone. Until now, though, after the topic has been kicked it around here for a few pages, the preference appears to remain subjective, rather than pragmatic (not suggesting that subjective views are unworthy of consideration, mind you). And yet again, this does not mean we do not continue to listen, or that development in this context is finished.
  9. #24
    Sep 2018
    SD
    23
    If an obvious and compelling advantage for the former approach exists, I'd be just as pleased to hear it as anyone. Until now, though, after the topic has been kicked it around here for a few pages, the preference appears to remain subjective, rather than pragmatic.
    I'm going to jump back into the fray here. For us, as a professional broadcaster we simply left the PTZ tab open almost all the time, and just loaded stuff onto DDR 2 or GFX 2, or fed a set monitor from DDR 1 or GFX 1. We only use 3 PTZ cameras plus occasionally a SDI camera or two. Are there that many people using more than 8 PTZ cameras? That seems like a lot to manage all by yourself, all while still cutting a show, managing graphics, video playbacks, etc.
    As a side note, I'm not a fan of trying to click the little sprockets to bring up the settings pages. It usually takes me 2-3 clicks in order for the hidden button to appear and to successfully click on it. And then, since the window disappears once you click anywhere else, it makes it more cumbersome to return time and time again to the settings pop-up.
    My suggestion would be to have the PTZ control in three places--lower left, lower right AND settings pop-ups for individual cameras. Then everyone would be happy! Another suggestion would be to make the old PTZ Control tab be a pop-out window that I can drag to my second monitor, where the multiviewer lives. Obviously it would have to be a persistent pop-up window, not one that disappears when you click elsewhere.
  10. #25
    19,396
    Quote Originally Posted by bwood View Post
    Neither am I. In fact, I virtually never do it. I just double-click the monitor (much bigger target), just like I double-click in the DDR bin to pop up the Media Browser. I mention this just in case it helps, not to quibble.
    By the way, although I've never been a fan of switching with a touch-screen - thanks to previous poor experience - with current generation gear this has seriously improved, to the point that its not only usable but is starting to feel like it will eventually be a norm, if not the norm (I really didn't see this coming). The reason I digress here is because if someone is using a touch screen, they may not have noticed that you can quickly and easily 'two-finger tap' an ISO monitor to access the controls. It's really very easy to do this, also works on a Multiview, and seems quite natural and convenient way to control a PTZ camera. For a setup like a council meeting that doesn't already rely on a custom control page, being able to switch with a single tap on a Multiview, and double-tapping the same ISO to change presets works quite well.
  11. #26
    Sep 2018
    SD
    23
    Good to know. I hadn't found out that shortcut yet as I don't personally cut shows on the system, so I'll pass word along to our staff.
  12. #27
    19,396
    p.s., double-clicking the larger Preview monitor will open the control panel for the source currently on Preview - which, in turn, gives you a very quick way to access the PTZ presets for the camera currently on Preview ... effectively a Follow Preview feature, to reduce hunting around for the correct viewport to use.
  13. #28
    Jul 2008
    Honolulu
    602
    For those of us that have to switch our own shows the new PTZ layout is devestating. Impossible to manage honestly and not interrup the show flow.
    Todd Cochrane
    @geeknews
    [email protected]
    http://geeknewscentral.com
    TriCaster: TC1 / 860 AE / Mini AE
    Skype: SkypeSarus
  14. #29
    Jan 2018
    Winter Park
    317
    Would be kind of cool if the upper bin that controls the MEs could switch between the ME and a PTZ long tab. If you select PTZ it would show the presets etc. Be able to enable it to follow on preview etc. Hide it when you don't need it.
  15. #30
    Apr 2016
    Lisboa
    32
    Nice to see this new forum thread on going!
    "I'm still interested in hearing any very compelling cases where the V2 PTZ implementation falls far short of its predecessor."
    Events type: conferences / "small" live events, with live presentations and recording.
    Tricaster TC1 setup detail:
    IN 1 - PANASONIC AW-UE70 (SDI)
    IN 2 - PANASONIC AW-UE70 (SDI)
    IN 3 - PANASONIC AW-UE70 (SDI)
    IN 4 - LAPTOP (SDI using decimator MD-LX converter)
    OUT 1 - PANASONIC RZ970 PROJECTOR (SDI)
    AUDIO IN - XLR L+R from external Midas Audio Mixer
    AUDIO OUT - XLR L+R to playback DDR's in room PA
    This is the usual setup in 4 of our auditoriums/conference rooms, all of them with same equipments. This setup and this needs are the same almost every day.
    Like I mentioned before: "Sometime we need to see PTZ PRESETS all the time", and this is totaly true in this case. Since we need to set our main focus in recordings/streamings, PTZ PRESETS are vital, of course. I wish I could see presets thumbnails of "Follow Preview" cam all the time, without a pop-up opened in middle of my interface!
    To be honest I just need to use the Audio Mixer to verify if the LAPTOP audio source is already set to EMBEDDED. Since V2 (and I'm grateful for that) I can even ajust the LAPTOP audio input from the new input windows fader! Same for DDR's, I just need to playback some short videos (and just when they are delivery early) otherwise they are playback trought the LAPTOP.
    SBowie, once again, thank you to make this discussion open!
