Results 1 to 2 of 2
Thread: Connect - Spark Wifi AP Login
    Nov 2018
    Edinburgh
    1
    I an trying to find the default Wifi Accesses Point password for the Spark.
    I can get logged on to the device via Eithernet, and setup the connect to login to a external wifi network as a client fine, but.......i cant find the logon for the NEWTEK-CONNECT Wifi Accesses Point.
    so as to be clear...
    1. I switch the Connect Spark on.
    2. I open my ipad/Laptop wifi and see NEWTEK-CONNECT
    3. I need the password to logon.
    Gavin
    I know the Spark shows up with an Access Point but it isn't designed to work that way. Log in while using wired Ethernet and then use the Administration web page to configure the WiFi on the Spark to connect to your WiFi Access Point of your network. Then you can run it wireless.
