Results 1 to 2 of 2
Thread: Blackmagic Smart Videohub and TC1
    Nov 2018
    Weslaco
    5
    Hello all,
    Does anyone know if it's possible to increase the TC1's inputs using a Blackmagic Smart Videohub? I've read literature that says it is possible, and I've even tried going into the router setup file, but the TC1 doesn't pick it up. Any suggestions?
    Cert. Tricaster Operator ZoLO's Avatar
    Apr 2011
    Hamburg, Germany
    18
    I just set the bmd_Config discovery mode to 'true' and it worked in an instant.
    IP addresses need to be in the same range, of course.
    in production setting, i would recommend to set fixed IPs (not dhcp) and use direkt IP/Port/name setup (as stated in "Full examples" within the 'router_setup' file instead of autoconfig..
    i have NOT tried using autoconfig AND fixed IP in redundancy.. but it should also work.
    (of course file needs to be saved and Tricaster needs to be restarted for the settings to take effekt)
    it is POSSIBLE, that the videohub needs to be powered up first, and Tricaster software started after that, to be discovered properly.
    First Certified Tricaster Operator in Germany
    Operating, Trainings & Support in Germany
    FatFish features
