Page 15 of 17 FirstFirst ... 51314151617 LastLast
Results 211 to 225 of 248
Thread: db&w Tools on Patreon
  1. #211
    Stuttgart, Germany
    13,682
    Quote Originally Posted by vonpietro View Post
    does db tools not work with 2018
    I have it for 2015 and it works fine, but i tried putting the plugin into the plugin dir in 2018 and it crashes.
    any issues with the old dbtools plugin running in 2018?
    date on the plugin is 2013 whew awhile back.
    its used on a gundam i have from xavier - he really made it compelex using some nodes i'd never seen before.
    We still have a non-Patreon release that works with 2018 here: https://www.db-w.com/products/dbwtoo...e-plugins-free
    However, since the node SDK changed for 2018 and higher, some nodes had to be dropped. Mainly the cache node and anything related to materials. This is also why older versions don't work with 2018+
    Cheers,
    Mike
  2. #212
    yup that was the node that didn't work anymore - do you know what it does?
    thanks for the free 2018 version.
  3. #213
    Stuttgart, Germany
    13,682
    Cache caches the evaluations of what's upstream. Basically, if an output is used multiple times in the same node graph, inserting a cache would only process the node the output is a part of once (any everything attached to that node further up).
    You can "replace" it by direct connections from the single output to the inputs where they're used.
    Cheers,
    Mike
  4. #214
    Stuttgart, Germany
    13,682
    Last month our patrons receive the Multi-Variables Node as well as the Elbow node to help them organise their node graphs.
    https://wiki.db-w.com/tools/multi-variables
    For this month, we've proposed three nodes: And Instance Filter node (to isolate instances), a Multi-Mixer node (similar to the morph mixer) as well as an Audio Frequency extraction node.
    Become a patron at https://www.patreon.com/dbw to get the current build of the db&w Tools, vote on the next tools as well as to follow and influence development.
  5. #215
    Aug 2016
    a place
    2,282
    fantastic, not had a chance to look at these yet, will get latest and check em out.
    thank you for all you work.
  6. #216
    Stuttgart, Germany
    13,682
    Thank you for your support.
    Cheers,
    Mike
  7. #217
    San Jose, CA
    6,885
    My digits are crossed for Instance Filter, but looks like it's going to come in last. Oh well.
    Glad to continue support, IMO supporters are receiving serious RoI!
    (edited to remove double post -- Newtek/VizRT please FIX the "Quarter-Till" Double Post issue!!!)
    John W.
  8. #218
    Aug 2016
    a place
    2,282
    I am hoping for an x64 of this http://www.pictrix.jp/lw/ReSize/index.html
    Not sure how I do a request for the vote list, so posting here.
  9. #219
    San Jose, CA
    6,885
    Worth asking, but I kind of had the impression they're keeping DB&WTools focused on Layout (where ReSize was a Modeler plugin).
    You wanted for Modeler, correct? By the time you took away everything ReSize did that Layout's SDK doesn't currently expose/support, there'd be little merit left.
    John W.
  10. #220
    Stuttgart, Germany
    13,682
    Maybe we should add more options that nobody wants at all.
    Thank you.
  11. #221
    Stuttgart, Germany
    13,682
    Here is fine. A comment on Patreon or our Discord is preferable though.
    John is right in that our focus tends to be Layout. I'm also a bit hesitant when it comes to copying another LW plugin. Not necessarily because it's the copy of an idea, but because somebody has already done the work and "only" needs to update it. Which is a lot easier than re-inventing the wheel.
    Cheers,
    Mike
  12. #222
    Stuttgart, Germany
    13,682
    Our patrons have voted and we'll be developing an Audio Frequency node over the next two months.
    The first steps will be shown in our development stream later this week.
    Become a patron now to get the current build and support our development at https://patreon.com/dbw
    https://www.patreon.com/posts/35988021
  13. #223
    Stuttgart, Germany
    13,682
    Do you have anything planned this Friday evening?
    Well, we do.
    Come and join us in our live stream discussing the latest development for patrons. The stream is available for everybody, make sure to set a reminder.
    https://www.patreon.com/posts/36060633
    Cheers,
    Mike
  14. #224
    Stuttgart, Germany
    13,682
    Just as a heads up, all future builds of the db&w Tools will include a version compatible with LightWave 3D 2020 as well:
    https://www.patreon.com/posts/db-w-tools-and-36316349
    The current Plugin of the Month, the Audio Frequency node, is well underway and we expect to deliver a first beta to patrons next week, after all of this LW 2020 kerfuffle is over.
    Cheers,
    Mike
  15. #225
    Stuttgart, Germany
    13,682
    We've released the LightWave 3D 2020 compatible version of the db&w Tools to patrons yesterday.
    We'll also be streaming the current state of the new Audio Frequency Node soon:
