Thread: UV mapping a human leg
    I need a UV map on a leg for mapping an even gridlike image. Only the leg, feet is not important.
    Can someone help me? Is there a tutorial somewhere?
    Thanks!!
    Freddy
    Aug 2016
    a place
    1,856
    use abf
    use plg to align
    https://www.lightwave3d.com/assets/p...try/plg-tools/
    or just use plg
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,526
    Plain ol' cylindrical mapping works as well, though you will have to manually open the seam along the inside of the leg.
    In this case, though, ABF is the tool of choice.
    My Scripts for Lightwave
    San Jose, CA
    6,513
    Quote Originally Posted by Cyberfish_Fred View Post
    So depending on how detailed the geometry is, it's going to fall somewhere between a simple cylindrical mapping, and a complex ABF unwrapping. If all you're trying to achieve is to get a grid-like texture to appear uniformly across the leg's surface, I'd definitely recommend trying a simple cylindrical mapping first (and then generate an ABF unwrapped UV map only if the cylindrical mapping results weren't adequate to your needs).
    John W.
    LW2015.3UB/2019.1.4 on MacPro(12C/24T/10.13.6),32GB RAM, NV 980ti
