Results 1 to 15 of 28
Thread: Daytime moon
    1,522
    Daytime moon
    I'm looking for some pointers on how to set up a node surface for a billboard of a 3/4 waining full moon in daytime. If you're where it's clear & noticed (been happening the past few days), the shadow portion just blends into the blue sky.
    In After Effects, I'd do something with a luma & alpha mattes, but not sure quite how to go about that in LW. I kinda sorta have it working but not with the contorl I'd like.
    TNX
    15,589
    TNX
    Fake it with transparency..if nothing is
    Behind the moon.
    Or if using hv sprite clip..try dissolve.
    Ive done this ages ago.
    At work having lunch..so I can't give
    A Proper showcase right now.
    15,589
    You should also use light incidence angle for any such gradient in dissolve or trasnsparency channel.
    19,455
    You know I'd never thought about this, yet it sounds right - which (at risk of a tangent) makes me wonder why this is so ... I could guess, but does anyone know the physics (or optics) involved?
    I don't know exactly why but if the shadow portion of the moon is as black as the rest of the sky around it then atmosphere "filter" is applied equally to both the black sky and black part of the moon making them both the same. I think?
    On some days when the shaded part of the moon is not as black and you can actually see it, also colored blue.
    Wasn't there a tutorial on exactly this in an very very old LW book (no nodes, though)?
    15,589
    Probably the same reason we do not see the dark space...atmospherics.
    And it will tint cover anything thst doesnt emitt light strongly enough.
    In the 3d world...a sk.sunsky is purely a backdrop
    ..we would need volumetrics to make the moon fade away where it is in a veil of shadows...and actually a strong light or volumetric light to simulate rays from the moon...and in such case it wouldnt work with a luminous surface on a sphere.
    15,589
    The basic stuff....though if you want something advanced such as a two moon or more moons hanging in a scifi-scene, and one moon obscuring the other, this wonīt be working so good with transparency.
    1,522
    I'm pretty sure it's just the refraction & skattering of the sky color; similar to why when looking into a hole poked in snow on a clear day looks blue too. I know we covered this in my college physics, but that was way too many decades ago.
    Axes grinder- Dongle #99
    Seattle
    14,737
    When the Moon is visible during (Earth) day, there's probably a fair amount of "Earthshine" hitting the moon, because obviously the Earth is quite bright at such times.
    TO THE INTERNET!!!
    "The Earth is much brighter in the Moon's sky than the Moon in Earth's sky. Not only is Earth 3.6 times 13 times larger by angular area, but its average albedo of 0.37 (meaning Earth reflects 37% of the Sun's light on average) is more than three times higher than the Moon's (0.11)."
    Praise to Buddha! #resist
    1,522
    I'll look into that. At the moment I've been just using a gradient.
    The scene is using an HDR enviro light & a Texture Environment for the bg and just using GI so not sure how you'd set incident angle for that.
    The billboard of the moon is a pretty high rez HDR as well an at present just using a Standard material. I am using some object dissolve (~38%) for transparency to blend but running into the issue of if I get the dark side to look correct, it's not bright enough for the lit side. I can kick that up some on the image map but it still wasn't right.
    I've a very subtle volumetric fog for atmospheric and letting that affect the moon object, so distance from camera becomes a factor.
    Ignore ground at present. That's a WIP. Still discovering some UV & texturing issues too.
    15,589
    TO THE INTERNET!!!
    To me it doesnīt sound reasonable that such earth shine would yield any significant energy for the moon to emitt that earth shine light back strongly enough to be visible in earth atmosphere.
    It would be secondary reflected light, sunlight first hits the earth and then need to travel to the moon, then reflect that "earth shine"light again back through earth atmosphere, and for the earth to have a full cycle of the whole earth shine, I suspecty the sun would need to be behind the moon in a straight line I guess, and thus it will loose any direct sunlight, leaving it with only the earth shine light to illuminate the moon, and maybe a slight rim light on the side of the moon.
    So I just donīt think that earth shine is contributing in a significant way to the appearance of the moon blending in to the earth atmosphere, picking up the same color which sort of gives the illusion of fading away.
    I am guessing itīs just air refraction together with atmosphere thickness that determines which light and how much is penetrating enough to be visible.
    I am no expert in physics though, so from me it is foremost guessing.
    6,686
    Exactly. The scattered sunlight in the atmosphere effectively "drowns out" both the darkness of space, and the darkness of the moon's shadow in the same manner. The only way things show through the atmosphere is if they're adequately brighter than the atmosphere's brightness level (also why celestial objects aren't typically visible during daytime).
    Darkness is the absence of light.
    15,589
    Yup...
    Maybe this may be helpful..though the question "Why transparent" actually is a false conclusion, and for the false world, transparent is exactly what the moon object is in my sample here, as a fake for the lack of atmospherics.
    https://www.quora.com/Why-can-you-se...it-transparent
    Cool Blood Red Day Moon...edge blending...LightWave...SpeedEDIT...father sun also...
    Who can forget the daytime blood red moon over the pyramids quite the blend-in also...:
    NDI Camera
    TriCaster Mini Advanced Edition
    Lightwave 11
    SpeedEdit 2.5
    1,522
    I switched to a Delta material for the moon object, and that with some matte & luma manipulation into a gradient for surface transparency is getting there. Think I need to kick the volu fog up just a bit or tweek distance settings. In any case, I'm just bummbling along with this so open to better techiques.
    Knocked the main enviro light down some as well.
