Results 1 to 14 of 14
Thread: Disappearing Beveled Text Polygons
    Dec 2008
    Kalispell, MT
    54
    Having a strange issue when beveling text. All appears normal in Modeler but the front faces of some
    letters won’t render, regardless of how I have the surfaces set...double sided etc.
    Beveling other shapes works fine, just seems to happen with text and only on some letters.
    I’m stumped. I hope someone has a fix to try?
    Thanks,
    Carl
    NewTek Social Media Chuck's Avatar
    Dec 2002
    San Antonio, TX
    6,399
    Caveat: I'm pretty rusty still after a number of years away from LightWave. If the text object is not all triangles, check Polygon statistics for non-planar polygons. This next may be an obsolete notion - zoom in on any corners and curves and see if you have any vertices located such that they cause crossovers in the sides of the associated polygons. Move those points to eliminate the crossovers. If seems appropriate you could also merge points.
    Chuck Baker
    Senior Manager of Communications
    NewTek, Inc., Vizrt Group
    [url=http://www.newtek.com][b]NewTek.com[/b][/url]
    [URL=http://www.lightwave3d.com/][b]LightWave3D.com[/b][/url]
    [url=http://www.facebook.com/newtekinc][b]NewTek USA Facebook[/b][/url]
    [url=http://twitter.com/NewTekInc][b]Twitter[/b][/url]
    [url=http://www.linkedin.com/company/newtek][b]LinkedIn[/b][/url]
    [size=1]Software Developer's Dilemma: The better the new feature, the more feature requests it will generate. - C. Baker :)[COLOR="DarkOrange"]
    Please note that any statements regarding future product development are forward looking and subject to change without notice.[/COLOR][/size]
    Dec 2008
    Kalispell, MT
    54
    Thanks Chuck. Not seeing any triangles. I just used the bevel tool on a piece of text I made in Modeler.
    I would think the bevel tool is defective if it produces polygons that won’t render.
    Carl
    Super Member Chris S. (Fez)'s Avatar
    Virginia
    3,040
    Bevel. Then triple to avoid render errors from polys over 4 sides.
    Post an image, if possible.
    San Jose, CA
    7,316
    Quote Originally Posted by ckeyes888 View Post
    Yes, that's just one issue among many with Bevel. It's an area where Modeler's been in desperate need of rework for ages, alas.
    If you really want to depress yourself, take a look at C4D's Bevel tool.
    John W.
    8,471
    I made plugin which allows generating beveled text directly inside of Layout.
    http://truetypetext.trueart.eu
    Some fonts are troublesome..
    I doubt it's Bevel issue. It's very easy tool.
    Polygon normal vector is calculated from 1st, 2nd and last vertex.
    If somehow (any) tool is generating one of them in the same location as second one, it'll result in making normal vector which has length 0 (instead of 1).
    And such polygon won't render correctly anymore.
    Dec 2008
    Kalispell, MT
    54
    Thanks all. Seems moving a few overlapping points around fixes the issue...but what a pain.
    Carl
    San Jose, CA
    7,316
    There are cases where certain arrangements of beveled intersections can wind up generating overlapping points/edges (perhaps even polys) using Bevel, depending on the precise geometry involved. AFAICT, such problems typically arise when you bevel segments close enough together they cause the resultant beveled+in/extruded edge segments to cross over each other, etc.
    John W.
    Bevel++ is very powerful for this, I use it almost exclusively on text
    https://www.tdate.org/lightwave/bevelpp/
    Dec 2008
    Kalispell, MT
    54
    That would be perfect except it seems to be PC only. Mac guy here.
    Carl
    17,854
    Yup...I want a serious improvment on the beveling tools, and yup...C4D bevel looks awesome.
    Blenders bevel isn´t as good as C4D, but you can at least check the clamp overlap.
    It needs a fix - right now it's not generating the right font look/curves. So it won't look like the font you have selected. Sorry, but I had to mention this in case someone jumped on it. Function wise it's great but had to give up using it because of the font issue.
    Any hope for an update Sensei?
    Michael Englyst
    Lightwave 2018.0.2 on an i5-4430S @ 2.7 GHz · 12 GB RAM · Windows 10 Pro
    Feb 2006
    Vancouver, BC
    1,664
    What we need is an Unf*ck tool.
    No, seriously: someone actually came up with a tool that fixes exploded bevel operations - it made me laugh out loud. And hey, as long as we have an Unf*ck tool, why not also have an Unbevel command?
    Crazy times. Really. Here's the video (starts at 1:20, unbevel is shortly before that):
    Win10 64 - i7 [email protected], p6t Deluxe v1, 48gb, Nvidia GTX 1080 8GB, Revodrive X2 240gb, e-mu 1820. Screens: 2 x Samsung s27a850ds 2560x1440, HP 1920x1200 in portrait mode
    Unf*ck tool.
    hm, quite nice!
