Results 1 to 9 of 9
Thread: Controlling the NDIHX-PTZ1 from a long distance
    Jun 2012
    Los Angeles
    66
    I know our NDIHX-PTZ1 camera, Skaarhoj camera controller, and laptop with Studio Monitor work perfectly on our network at our school. I've seen it. It's beautiful.
    However in the football field, I want to operate and send the camera's signal (placed behind an end zone) 700 feet to where the Tricaster will be.
    In testing, when I plug the camera's Ethernet out into an Ethernet to fiber converter, then run the fiber to a 2nd Ethernet to fiber converter, then plug the Ethernet cable from the 2nd Ethernet to fiber converter into the Ethernet switch that also has the camera controller and laptop with Studio Monitor connected to it, I got no picture and I can't control the camera. I reboot, reconnect, etc... but this setup isn't working.
    How can I control the NDIHX-PTZ1 from a long distance? Is the Ethernet to fiber converters suspect? Are Ethernet Extenders the way to go? How can this be made to work?
    Help please. Thank you.
    If you put something else on the end of that Ethernet to fiber converter, does it show up? (if it is a laptop, can you ping it?)
    Key Accounts Sales Engineer
    Jun 2012
    Los Angeles
    66
    K,
    I'm not at school yet but will try as soon as I get there. Can I ask: What if the laptop doesn't show up? What if it does?
    Thank you.
    Max
    Jun 2012
    Los Angeles
    66
    Kane,
    I am at school now. The laptop on the end of the Ethernet to fiber converter does have internet access. It is what I'm on now typing this reply.
    Max
    Apr 2008
    Racine
    1,602
    Is camera powered via AC adapter of PoE?
    Jeff
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jun 2012
    Los Angeles
    66
    AC Adapter
    Apr 2008
    Racine
    1,602
    Same ethernet switch that has worked before? Must be Gigabit (10/100/1000). Also read something the other day about older ethernet cables maybe not being fast enough for Gigabit? Are your cables at remote site known to be Cat-5 or Cat-6?
    Jeff Pulera
    Jun 2012
    Los Angeles
    66
    Got the right equipment and it works:
    2, LMC4000A Micro Mini Media Converter - Gigabit Ethernet SFP (https://www.blackbox.com/en-us/store...t-SFP/LMC4000A)
    2, LFP413 LC Connector / SFP - 1250-Mbps, Extended Diagnostics, 1310-nm Single-Mode Fiber, 10-km, LC (https://www.blackbox.com/en-us/store...0-km-LC/LFP413)
    1, 1000' Fiber Optic Cable
    These items worked in our environment. You may need slightly different model numbers or connector type, but the company (black box) knows their stuff.
    Good luck to everyone!
    Jun 2012
    Los Angeles
    66
    Exclamation
    Quote Originally Posted by mtash View Post
    2, 1000' Fiber Optic Cables
    CHANGE TO ORIGINAL POST:
    You MUST have 2 (not 1) Fiber Optic cables connecting the Transmit & Receive ports of the two Micro Mini Media Converters and the Tricaster.
