Page 1 of 4 123 ... LastLast
Results 1 to 15 of 48
Thread: LW2019 - Layout viewport performance with active modifiers fixed - Thank you NewTek!
    Jun 2014
    Right here
    1,993
    One of the issues I reported - the viewport performance slow down with active deformers is fixed in LW2019.
    Thank you NewTek for fixing this!
    (Case LWB-3970) LightWave Layout viewport is slow with high poly objects and active Deformers in Modifier Stack
    Issue LWB-3970 has been marked as CLOSED.
    Improvements in LW2019 have fixed this. Deforming meshes are no longer being rebuilt for OpenGL if the mesh hasn't changed.
    So the build they are working with is being called 2019? If it is that sounds like they intend to try and get a yearly release going which would be nice as long as they can pack it with enough value.
    Quote Originally Posted by Nicolas Jordan View Post
    I guess we will see come Jan1.
    Tim Parsons
    pass:sword OFF's Avatar
    Russia
    1,121
    Thank you, I am also looking forward to these changes. Let's hope to see all this in the near future.
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,203
    We just have to wait and see... lw2018 was called lw2016 long before it was released.
    Super Member Paul_Boland's Avatar
    Nov 2003
    Waterford, Ireland.
    1,106
    How do we view our submitted bug reports so see what their situation is?
    KnightTrek Productions
    http://www.knighttrek.com
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,671
    There should be a link on your account page, the one where you download Lightwave from.
    My Scripts for Lightwave
    Maybe that's just what they are using as a name then until they decide the build has enough stuff to push out as an upgrade. I still don't think the yearly naming convention makes any sense unless they are intending to try and put out a new version every year.
    May 2003
    Ohio
    1,333
    They should name it Lightwave CC so there is no obligation to add any new features but ensure a steady revenue stream. Surely this is an original idea.
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive.
    Active LW Development in 2020: DB&W | Deep FX | DPont | LWCAD | TrueArt | ...
    Sep 2017
    MA
    63
    LW 2019??
    Whoa. What secrets do you know, Marander??
    Nov 2003
    Waterford, Ireland.
    1,106
    Thanks. Found it. A number of open bug reports but none I can see that mention being fixed in 2019.
    San Jose, CA
    7,315
    If accurate, that'd be a strong indication Newtek has already "switched over" from working on LW2018 updates onto the next paid version upgrade.
    Considering how few actual issue fixes and improvements came in those "six updates" (Newtek even acknowledged they were tiny with the .0.x designations), and the current state of LW2018 in terms of broken/incomplete functionality, Newtek declaring LW2018 "done" would be a horrible mistake, IMO. Of couse, it wouldn't be their first such mistake, nor even the least bit surprising that they'd make such a mistake again so soon after the last.
    Oh well, I'm sure the Faithful will be along to circle the wagons and declare how wonderful LW2018 has been for everyone. Good luck with that.
    John W.
    Russia
    1,121
    If we do not raise the question of the level of implementation of the LW instruments, then with regard to production, the main problem is constant lags - this accompanies you in each more or less large scenes. Take the landscape with instances, add a couple of characters with FFX and the performance will drop to almost zero and equal the performance of the LW 5-6 versions. To this we need to add hang-ups between Layout and Modeler, when you work with more or less complex objects and scenes.
    And in sum, we get a product that works with persistent problems, which even various fashionable features do not save.
    I really hope that they will be able to put in order at the next version of LW their Hydra-engine. This would smooth out my personal negative impressions of the overall performance. The potential of the Hydra engine is good, but the realization of this is still very raw.
    San Jose, CA
    7,315
    Certainly doesn't seem like they've done so for LW2018 given current state. Little to no reason to expect them to do better for LW2019.
    John W.
    I agree it does sound like they have moved on to having an early build of the next paid version. If this is the case I assume then that any bugs fixed will only be fixed for the next major release. It would be nice if they were able to bake out bug fix builds for 2018 from the internal 2019 build but I doubt that's even possible.
