Page 5 of 5 FirstFirst ... 345
Results 61 to 68 of 68
Thread: nuArchitect python version
  1. #61
    May 2017
    Lampertheim, Germany
    124
    List of improvements
    Hello,
    here the list of improvements to nuArchitect:
    The place for the (many) libfiles is moved to a subfolder of the "site-packages" folder (so as python wants it).
    improved UI
    specialized controls for special tasks
    own controls for
    . show sketch
    . messages
    . titles
    . size of dialog
    . UV-Map handling
    . Icon editing (PY)
    . Image to PY-List
    many requesters
    drastically improved TGA creation-speed
    possibility of crating other formats than TGA (needs installation of image manipulation libs)
    . more details in the help for the scripts
    using Tab in Tab UI
    for script coders garbager-window(s) and some script generators
    UV handling more structured
    option to save the UV-settings per nuArchitect script added
    improved path-handling
    improved message handling
    remembering of app-data
    allow load and save of app-data
    nuArches
    minor improvements
    nuArchStones
    now possible to scale every 2nd stone
    nuArchWay
    complete new script to create archway tunnels
    nuBridgeStones
    arches now allow scaling of every 2nd stone
    different settings for wall and crossing
    new wall creation (no more full stones, only skin)
    added option for small pedestals to every pole of the parapet
    poleheight adjustable
    improved handrail creation
    nuCathCei
    option to create edged ceilings added
    option to set the detail level added
    option to set the roughness added
    count of bows in x and y direction added
    nuCirclePlan
    improved mortar creation
    nuColumns
    a new column-top type added (scaled)
    a new column-bottom type added (scaled)
    option to twist the column-body added
    some improvements to the geometry itself
    nuCrackedStones
    more realistic cracks
    options for edges sharpness added
    subdivide options added
    roughness per axis added
    nuDoors
    keyhole separated
    option to twist lattice-struts added
    option to use planks to create the doorblade added
    option to add struts added
    option to create a simple peephole (and peephole door) added
    nuFences
    option to subpatch posts and pales added
    option to create posts and pales with adjustable edge-sharpness added
    nuFloors
    complete new way to create the geometry
    new randomtype floor added
    nuFountain
    2nd type of bowls implemented
    option to create a socket added
    option to twist the column added
    bowls can now be positioned in y direction
    more detailed settings added
    option for old bowltype to be twisted added
    option to create uv for every bowl added
    nuGates
    option to use full framed arches insted of wire
    option to use stoned arches insted of wire
    interior of an arch and exterior of an arch can both be wall or flat
    option to twist the rods of the lattice
    option to create mounts
    improved sketch drawing
    nuGothBlk
    option to set different archscales added
    detail options added
    roughness per axis options added
    the lower wall (if one) height can be defined
    offset option added
    nuGothXPass
    complete new way to generate the passes implemented
    option to use different looks added
    option to generate a pass-cutter only added
    option to generate the pass-points only added
    option for detail level and roughness added
    nuGroundPlan
    option to use skin only added
    option to create 6 different skin looks added
    nuHeavyGate
    option to use different walltypes added
    option to use different archtypes added
    hinges from file added (hinges can have 3 parts now)
    rivets can now be placed free
    UI with more sketches
    nuOrnaments
    option to double the cross-section added
    nuPedestals
    detail option added
    complete new handling of the scalers
    option to save the actual scalerdefinition to use it in the future
    nuPlaque
    aging per axis added
    nuRoofGable
    option to create roof as full or skin
    different wall types added
    option for roughness per axis added
    mortar dimensions can be set more flexible
    nuRopePath
    improved cross-section for ropes
    some formulas to create path added
    option to create a spool added (wrapped rope/chain)
    nuRopes
    complete new way to calculate the catenary
    two different ways to calculate the catenary
    way 1 is using a parabola
    way 2 is using a startpoint vector, an endpoint vector, a gravity vector and a gravity value
    nuRota
    improved handling of points
    detail option added
    nuSockets
    new way to create the main parts
    more flexible sharpness of the main structures edges
    plaque text separated to own tabs
    nuStairStones
    new way to create stones
    old way as option added
    nuStoneSkin
    new way to create tubes
    new walltype added
    random of new walltype per axis added
    UV-mapping of tubes now cylindrical
    nuTombstone
    new way to create the tombstone
    nuUV2TGA -> now named nuUV2Image
    integrated in every script with an UV-Tab
    also as stand alone script
    nuWallStones
    dedicated roughness per axis for all parts
    new walltypes added
    positioning sketch added
    new passtypes integrated
    improved arch creation (and windows)
    nuWell
    new roof type added
    nuWinsGoth
    more pass types added
    more pass variants added
    nuWinsStd
    now every window type has 4 variants
    the frame now has sharp edges (even subpatched)
    the sill has sharp edges too
    the sill can now be switched off
    nuGUIDesign2
    is completely new coded
    Controls can be placed per "drag & drop"
    The buttons to manipulate the GUI are widely extended
    nuSOFT controls (non standard controls) as in nuArchitect can be placed into the GUI
    Some controls creating per default some code to make them run
    Tab in Tab will work in a new way (this makes them unlimited in depth)
    CTRL-C and CTRL-V can be used to copy and paste selected controls
    many shortcuts implemented
    Regards,
    Kanuso
  2. #62
    Frequenter
    Munich
    342
    Wow... Just: Wow!!!
    I hope I find the time to try these soon. Impressive achievement! Thank you!!!!
  3. #63
    Yes....wow!
    www.ernestpchan.com
    www.zazzle.com/gopuggo
  4. #64
    Murcia, Spain
    3,004
    Cant wait Kanuso, looks like a great update. The help files seem good as well by the way.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
  5. #65
    France
    498
    It sounds good, but the best is to test to better realize
  6. #66
    May 2017
    124
    nuArchitect V2 Python bundle - installation
    Hello,
    here the files you need to install the nuArchitect V2 Python bundle.
    This bundle is donationware. If you find it useful, you should consider to donate a small "thank you" via PayPal to [email protected]
    By using the scripts you accept that I'm not responsible to any damage that may result by using the scripts.
    The files to build the 'nuSoft' Folder:
    nuArchitect-data3.zip
    nuArchitect-data2.zip
    nuArchitect-data1.zip
    The file with the working scripts in it:
    nuArchitect-work.zip
    The file with the libraries in it:
    nuArchitect-libs.zip
    A script to aid you in Installation:
    nuTellPath.zip
    A cfg file to implement a submenu in the LW Modeler (no must for this):
    nuSoft.zip
    A dummy library to let nuGUIDesign2 work (only used to avoid a python error):
    guiedit.zip
    What to do with These files?
    Here a description working on Windows (for other installations you can get ideas from here):
    1) Download the zip files
    2) Open nuTellPath.zip
    3) Copy the file nuTellPath.py from the nuTellPath.zip file to where you want
    4) Start the Modeler
    5) Switch to the Utilities Menu
    6) In the Category Python click Python
    7) Navigate to where you put the file nuTellPath.py and open it
    8) Here you see information about installing the bundle
    9) With your OS navigate to the first folder that is listed in nuTellPath.py
    10) Open the nuArchitect-libs.zip file
    11) Copy the folder 'nuSoft' and all subfolders to this Location
    12) Copy the file "guiedit.py" from the zip file "guiedit.zip" to the first folder (directly in "site-packages")
    13) With your OS navigate to the second folder that is listed in nuTellPath.py
    14) Open the nuArchitect-work.zip file
    15) Copy the folder 'nuSoft' and all subfolders to this Location
    16) Navigate the 3rd folder control to where you want the nuSoft-folder to be
    17) With your OS navigate to the third folder that is listed in nuTellPath.py
    18) Open the nuArchitect-data1.zip file
    19) Copy the folder 'nuSoft' and all subfolders to this Location
    20) Open the nuArchitect-data2.zip file
    21) Copy the folder 'nuSoft' and all subfolders to this Location (if you are asked for Integration, answer YES)
    22) Open the nuArchitect-data3.zip file
    23) Copy the folder 'nuSoft' and all subfolders to this Location (if you are asked for Integration, answer YES)
    24) Click the upper "Check" button, it should say OK
    25) Click the middle "Check" button, it should say "Missing nuSoft.dat"
    26) Click the lower "Check" button, it should say OK
    27) Click "Create nuSoft.dat"
    28) Close nuTellPath.py
    29) Close the Modeler
    If you want you can do
    30) Copy the file "nuSoft.cfg" from the zip "nuSoft.zip" and use it as a config file to create a Modeler Menu Branch (read LW instructions for how this can be done)
    Now open the Modeler again and have fun
    Known issue:
    If you main Monitor is configured to a Resolution lower than 1960 by 1080, the working scripts are opened partially outside of the view and
    nuGUIDesign2 isnt fully usable.
    I hope this Installation hints lead you to success. You will find additional Information in the install.zip posted some Posts before this one.
    At the Moment there is an empty "examples.html". This will coming soon if it is realy needed (many Images).
    Regards,
    Kanuso
  7. #67
    Jan 2017
    Lenzkirch
    110
    HI,
    I'm redoing my puter, does this work with LW 2015?
    Thnx
  8. #68
    May 2017
    124
    Hi Stardust,
    no, the scripts do not run with versions before LW 2018. All scripts are tagged with
    __lwver__ = "2018"
    You can try to change the tag on every script. some scripts may run with a tag for LW 2015. You can try this, if you want, but without changes the scripts will not work with Versions before LW 2018.
    Regards,
    Kanuso
