Results 1 to 8 of 8
Thread: Texture
    Registered User Rizwan's Avatar
    Aug 2005
    Huntsville,Alabama
    89
    Texture
    I went online to download a texture. I want a brown hair texture. I made sure the texture is a jpeg image so I can open my texture in LightWave. When I move the texture to my desktop I try to see if the texture will open in Lightwave Modeler. When I open the surface editor to load my texture. I open up the Surface Editor. On the top right hand corner of the Surface Editor I change the material from Principled BSDF to Standard. Ok now on the side I have the E and T buttons enabled. I click on the T button on the first row which says Color. After I click on the T button and then I go to find the image in the texture editor. And the image which I downloaded is greyed out even though it was a jpeg image. How do I get the greyed out image to open?
    San Jose, CA
    7,222
    Are you sure you have read permissions for that location?
    Are you perhaps running LW as admin, and attempting to access a network location? If so, admin-elevated apps don't have same access perms as user-level apps when it comes to network resources ("split-token issue") and that could be causing the problem.
    John W.
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,925
    I've downloaded jpeg's that won't load into photoshop. Luckily I also have Affinity Photo which loads them fine and resaved them as.jpg. My guess is you have the same thing going on. Something is up with the format.
    ex-LightWave documentation BeeVee's Avatar
    Pessac
    5,266
    @Rizwan, have you tried just dragging and dropping the image icon over Layout or Modeler to load it?
    B
    Ben Vost
    LightWave 3D Docs wiki
    AMD Threadripper 1950X, Windows 10 Pro 64-bit, 32GB RAM, nVidia GeForce GTX 1050Ti (4GB and 768 CUDA cores) and GTX 1080 (8GB and 2560 CUDA cores) driver version 456.71, 2x4K 23.5" monitors
    Check to see if it is CMYK - LW doesn't like them. Needs to be RGB.
    Tim Parsons
    I'm not sure if a jpeg image can be CMYK. I could be wrong about that though.
    Quote Originally Posted by JamesCurtis View Post
    It most certainly can. And LW doesn't like them.
    Tim Parsons
    May 2003
    Ohio
    1,290
    A link to the texture could explain a lot.
    If the image opens in Photoshop, "export" in newer versions or "save for web" in older versions to JPG. This process can strip cruddy metadata and ensure you have a RGB image (not CMYK).
    LW4, 7.5D, 2015, 2018, 2019, 2020 running portably on a USB drive.
    Active LW Development in 2020: DB&W | Deep FX | DPont | LWCAD | TrueArt | ...
