Results 1 to 2 of 2
Thread: Embed Render Properties in Render as Metadata?
    May 2012
    Virginia
    431
    Does anyone know if there has ever been a plugin that might allow the user to choose to embed their Render Properties in an image output as data?
    When I'm testing different renders, it would be great to be able to just save out an image that has the Render Properties that I used embedded in it for comparison / quick reference.
    Jan 2005
    Colorado Springs
    1,795
    If you use Save RGBA with either JPG or TIFF format, the Metadata is stored with the file. You can bring the saved image file into LW using the Image Editor, then press the Metadata button to see the LW rendering metadata:
    There may be other file formats which support extended information (i.e. metadata).
    mTp
