Results 1 to 14 of 14
Thread: How do I keep my TriCaster Mini cool?
    Jul 2013
    Kansas
    470
    We just recently got a new press box. Very nice for sure, but they cut out air conditioners. The front is almost all glass and it is like a green house inside. It is hot to say the least. It will be 90 or more tomorrow which means it will be around a 100 or more in the press box. There are windows but only to let in 90 degree heat which won't help anything.
    I was getting it set up the other night and it just kept locking up on me and wouldn't even shut off. The control surface stopped working and it was just not usable.
    Does anyone have any ideas on what to do??
    HELP!!!
    1,656
    Air is taken in around the edges of the side panels and exhausted out the rear, so set up a small table-top home/office type of fan to blow air into/across the unit to keep airflow moving.
    Jeff Pulera
    TriCasters: Mini with AE, TC1
    Camera: Sony PMW-X70 4K
    PTZ: Newtek NDIHX-PTZ1
    Jul 2013
    Kansas
    470
    I'm doing that now. It sounds like it should help. We'll find out when we start. Have you ever worked in conditions 90+ degrees hot?
    1,656
    Yes, I've done a 4th of July parade for a few years now using Mini, and later TC1, and they have me stuffed into a small utility trailer with obviously no AC, and I just have to run fans and sweat quite a bit. No TriCaster failures, but it is worrisome to be sure when you are live via satellite on TV and failure is not an option.
    Jeff Pulera
    Jan 2018
    Winter Park
    317
    It only locks up in the heat? Inside with AC and everything is AOK?
    Jul 2013
    Kansas
    470
    I think I found out is was a combination of things. Crappy update was one of them. Then, Not telling you that you had to install some microsoft sercurity crap. I had to do a search to find out the errors I was having.
    That you also needed to update the Nvidia driver and also the intel driver.
    It is running better than ever now, and just quicker than heck to start. Part of that is because I had an SSD installed instead of those crappy WD drives they have installed in the mini. I have gone through over 5 WD drives. This SSD has been great. Newtek should just bite the bullet and install SSD drives from now on.
    Jan 2018
    Winter Park
    317
    Yep, glad to hear it's running much better for you. More airflow won't hurt anything though and you can get a portable AC for rooms like that of Amazon fairly cheap. Running for a game day it will pay for its self after one day :-p
    Jul 2013
    Kansas
    470
    With the portable AC, doesn't it have to vent outside?
    Jan 2018
    Winter Park
    317
    Sure does but the one I snagged off Amazon has a good length of flexible pipe for venting along with an adapter to insert it into a window . I have used it in places where we have the hose go out the door and the door cannot close all the way but is still significantly better than just an open door .
    Nov 2016
    South Dakota
    81
    Can you link the one you bought?
    Jan 2018
    Winter Park
    317
    Quote Originally Posted by ctc2010 View Post
    Honeywell MN10CES
    I think they are on a newer hardware but the thing cranks along and you can drain it when needed or run a hose line for constant draining etc
    Jan 2015
    Salem, OR
    35
    Quote Originally Posted by ingeborgdot View Post
    Ingeborgdot, my hard drive seems to be going out, and I would much prefer to replace with an SSD. Are there any tips or tricks to it?
    Also, could you please share what MS security program? And what Nvidia driver? And Intel driver?
    Thanks.
    Jan 2015
    Salem, OR
    35
    JPulera, my Mini is also overheating (and the fans are very noisy). Is that really all it takes is a small table fan at the edges? (Meaning, it doesn't take much?) Would it be too much to take the side plate off, and point the small table fan right at the metal grill? (Meaning, would that be overkill?) Thanks.
    1,656
    Quote Originally Posted by Nazarene View Post
    I'm not suggesting to open up the Mini. Quite plainly, as with any piece of electronic gear that generates heat, AIRFLOW is king. Just having air moving across the exterior as from a small fan is going to PULL HEAT off the unit and drop the internal temp considerably. Can't hurt trying
    Jeff
    Jeff Pulera
