Results 16 to 30 of 34
Thread: Controlling speed of travel along a spline/path
  1. #16
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,137
    The idea of using wind to push a particle to accumulate a value is very interesting. I have been playing with it and I think the attached setup works. It needs DP Kit particle info so I don't know if we can get something like this to work in Lightwave 2018. In the attached scene the Z direction of a Wind object uses Channel Follower to follow the heading of a control null. A particle emitter emits a single particle which is blown in the Z by the wind. A null uses DP Kit Particle Info node to follow the position of the particle. And the light uses Follower to follow the Z position of the null to animate it along the spline. I also added Cloth FX to the control null so that the calculate button would be available instead of having to select the emitter after each edit to see it. Quite convoluted.
    use_particle_wind_to_accumulate_valeu_v001.lws
  2. #17
    Aug 2014
    South Bend, Indiana
    420
    Something like this seems like it would be very easy to script... kind of surprised there is no "speed" plugin already.
  3. #18
    Axes grinder- Dongle #99
    Seattle
    14,737
    Quote Originally Posted by TheMightySpud View Post
    Well finding out the length of the spline is relatively easy (just move the object to the end of it along the Z Axis as normal and make a note of the number at the end. I can GET the speed of the object travelling along the spline no problem with a little maths, problem comes when trying to accurately SET the speed.
    ?? Yes, if the spline path is straight, and if it is not a motion path with TCB or any interpolation at its keyframes. @^@
    Praise to Buddha! #resist
  4. #19
    @Lertola2 - I had a quick play around with the particle idea (having gotten the Motion Info node working finally), but the problem I had was getting the kind of control I need (same reason I haven't used bullet 'car rig' tools)
    @Jeric - Using the built in Spline the path is technically always 'straight' as you only edit the Z axis to make the object travel.
    @Squarewolf - I did have the thought of editing the Cruise Control lscript that comes with LW to add in functionality to be able to select a Null and Axis to control the speed, but I'm not a scripter/coder so it's kinda baffling to me. lol.
    I am however going to have a look at the Maths involved in Cruise Control and see if I can recreate it using nodes.
  5. #20
    Aug 2014
    South Bend, Indiana
    420
    I don't know much about coding but I don't think that will work, you need to be able to accumulate value over time and the only way I think that is possible is with particles or bullet.
  6. #21
    Aug 2010
    Kernow
    2,078
    Quote Originally Posted by squarewulf View Post
    Yep. If I drive from Plymouth to London in four hours, then how fast was I travelling through Exeter, in rush hour?
    No amount of maths is going to give you the correct result, given the limited information.
    Attached Files Attached Files
  7. #22
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,164
    Hi all,
    Hopefully someone can help out cause this has been driving me nuts for a few days now.
    I have an object travelling along a spline. But what I want to be able to do is have the speed the object is travelling controlled by a null (Note: Speed, not distance).
    I was trying to figure out a way to link the Cruise Control motion plugin to a null, but have gotten nowhere. And then I found an old thread on here that uses the Item Motion node from Dponts nodes. Problem is, that particular node doesn't seem to have been updated in the latest LW11 release of the nodes, and the LW9-10 version kills Layout.
    Would anyone have a solution that works in 2015.3 ? I did think some kind of expression may work, but I have pretty much no knowledge of expressions. :-/
    I hope someone can help.
    TheMightyspud
    You say speed not disstance? you know that speed is defined by distance over time, don't you?
    As you do this in Lightwave I assume that it's going to end up as an animation and not a realtime app, so why do you need to control the speed with a null? it is possible but sometimes its just as easy to work straight in the graph editor.
    Here's an example with spline control. I hope it can help or give ideas.
  8. #23
    Aug 2010
    Kernow
    2,078
    I think we might have a winner!
  9. #24
    Seattle
    14,737
    It's possible the OP was anticipating many revisions and just wanted an easy control to vary the speed, versus setting keyframes.
  10. #25
    Super Member Qexit's Avatar
    Warrington, UK
    1,118
    It's a pity Worley's plugins are no longer available as there is one in the Polk collection called VelAccel that would probably meet the OPs needs. It was part of the Henry Clay Collection that came as a bonus. The full description was:
    VelAccel
    Allows you to keyframe object velocities instead of positions. This makes smooth parabolic arcs easy (negative Y accel, constant X and Z velocity.) It can also be useful to make smooth accelerations of cars, since keyframing a smooth acceleration is hard.
Name:	VelAccel Panels 01.jpg
    I never had a use for it myself but just loaded it up in LW2018.0.6 after dusting off my old USB dongle so it would at least try to work.
    Kevin F Stubbs
  11. #26
    Jun 2003
    Sweden
    4,164
    Yes, but if you use a null for doing so you only transfer the keyframes to that null instead of your object. You don’t really gain anything, sometimes its easy to overthink and complicate things instead of just do it.
    I don’t say there isn’t a reason or that you should not do it but you should think it through before you do it.
  12. #27
    Jun 2003
    Sweden
    4,164
    Quote Originally Posted by Qexit View Post
    Why is that hard? Its very easy, I think. Please enlighten me why its hard.
  13. #28
    Warrington, UK
    1,118
    I have no idea. That line is simply a direct copy of the plugin description from the manual which is dated June 25, 1998
    Kevin F Stubbs
  14. #29
    Jun 2003
    Sweden
    4,164
    Ah OK. At that time I can understand it was hard but now the tools are a lot better and its not that hard anymore.
  15. #30
    Seattle
    14,737
    Another possibility is that the null controlled MANY other items.
    I can certainly see how this would be convenient if one were, for example, animating a bird's eye view of a car race with a basically circular track, but not an actual circle. Each car would get a "throttle", and blah blah blah. Of course, by the time you got this system working, you could have animated it w/keyframes three times over.
    Still, it'd be nice to know if the overall system is flexible enough to accommodate such constructions.
