Thread: N and K nodal inputs for IOR values
Hybrid View
    Here is a 2015 Nodal setup that allows N and K values to be converted IOR of real materials like metals, plastics, crystals, glass, liquids, etc. This node setup does require one plugin that one can get from here. (https://www.db-w.com/download/catego...vious-releases)
    The values can be converted from this website (https://refractiveindex.info/) per color channel. The wavelength values per channel should be: 0.65 for Red, 0.55 for Green, and 0.45 for Blue. I have these also stored in the description line of the compound node. Also there is a roughness setting just for fun. The samples attached show some of the compounds I tested with. They are in the node setup.
    Example: Pick Aluminium - place .65 in the wavelength value. Place the results for N and K red channels. repeat for green and blue.
    Enjoy,
    -m
ID:	142756   Click image for larger version.
ID:	142757   Click image for larger version.
ID:	142758   Click image for larger version.
ID:	142759   Click image for larger version.
    Murcia, Spain
    3,012
    Thanks, very useful.
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2019.03
    Very nice Laptop
