Results 1 to 10 of 10
Thread: ABF correction / "magical" procedures? / academic question
    Axes grinder- Dongle #99
    Seattle
    14,741
    Question ABF correction / "magical" procedures? / academic question
    UV mapping seems to be the Hawt Tawpic.... so here's an academic question:
    Regardez cette zjhayyyy PEGG, si vous plait:
    The original object was a straight "box", then tortured with Twist and Bend. The UV map is an untouched, raw ABF mapping. (Pretty good!)
    Obviously, to get the UV back to a "straight" representation, one could just get a coffee, buckle down, and start moving points, but for those who are conversant w/the UV tools: Is there any better* way to regularize the UV map?
    ABF test ribbon.lwo
    *besides going back in time and approaching the problem correctly. It's an academic question.
    Praise to Buddha! #resist
    Dreamer Ztreem's Avatar
    Jun 2003
    Sweden
    4,201
    If you start with a box I suggest you UV map it before you deform it then it will stay straight.
    Seattle
    14,741
    Read the footnote.
    Jun 2003
    Sweden
    4,201
    Ok, missed that. But sometimes it can be easier to start over and make it the right way instead of trying to fix it afterwards. Your example model seems like a very easy model to just redo.
    Seattle
    14,741
    Yeah, but it's just an example I whipped up to illustrate the point. For a REAL object, with complicated curves, some method (apparently PX UV Creeper, until it's not available/compatible) would be good for users.
    It's pretty gratifying, to me at least, what a good job ABF actually does.
    Near Beaverton, OR
    2,034
    Just thought I'd post these as a consideration:
Name:	Back in Modeler.jpg
ID:	142706 Click image for larger version.
Name:	In Rizom.jpg
    Literally took ~ 4 clicks not counting the export settings. Didn't even have to select edges as they were already cut in this model. Just Unfolded, Packed and then used the Straighten options.
    Didn' t even have time for the microwave to reheat a mug.
    The Big Apexx System:
    64GB
    Seattle
    14,741
    Rizome, ehhh? ::rubs chin::
    Pretty flippin' magical. --- Are there options for maintaining a correspondence between polygon area and the resulting UV area? Or is this a byproduct of the Straighten option?
    Jun 2003
    Sweden
    4,201
    This is not magical it’s what most decent 3d apps can do native or with some plugins. It’s just a proof of LW lack of UV tools.
    Near Beaverton, OR
    2,034
    You have SO much control. Island groupings. Locking options. Individual island packing preferences. A lot of "I didn't know you could do that with UV's."
    https://www.youtube.com/channel/UCIe...ouhXYL1pL45Zug
    The Unfold 3D vids are the beta of RizomUV. But you'll probably find this one of particular interest:
    https://www.youtube.com/watch?v=LfeHPBq1yYs
    Take note at the 3 min. mark of feature found in the menus & not in the UI.
    But also in case you haven't seen them:
    https://vimeo.com/282394320
    https://vimeo.com/284859229
    Not needed to use RizomUV, but nice to know the tools are there.
    64GB
